Hi,
I am about to install a new 6 gal atwood water heater in my Tradewind and am wondering about performance when not level. I know the refrigerator needs to be as level as possible to function. As you can see from the attached drawing, it will be impossible to install the water heater level because of the sloping exterior walls . . . will the heater work? Does or did the factory install the heaters at an angle? Maybe the walls on new airstreams are less angled/curved(?). Any advice / experience will be appreciated, thanks.
Mark
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
You should not have any problems if the unit is off level a few degrees. Water heaters are not level sensitive to any significant extent like refrigerators are.
Hey Mark,
Nice drawing! I just finished an Atwood 6 gal. DSI water heater install in my 65 Safari. I first removed the old 9 gal. Bowen and then installed a piece of alum. to reduce the size of the opening to fit the new wh. I planed it so that the Atwood sits on a 3" block of wood. by raising the new wh 3" I was able to get the door to match the side of trailer pretty well. Not sure if any of this would apply to your Tradewind.
Best of luck,
__________________ Tim
TAC MI 14
Everyday is a Saturday
Question all I have a 1975 Argosy Airstream and have purchased a new hot water tank and am about ready to install but here are my issues:
I have two copper pipes coming from the rear of the Argosy one high and one running on the floor that I believe is my incoming city water , question do these hook in to the water tank????????? also on the floor in front of the water tank a copper pipe is cut that leads to the fresh water tank how do all these pipes hook up ????????????photos would really help .
All this was done before I purchased to restore.
New to this issue of installing a hot water tank need help ASAP Help!!!!!!
One line from the pump is "cold". It should be connected to the lower port on the water heater along with the city water pipe.
The hot water pipe connects to the upper port on the water heater.
This would be a good time to install the 3 valves required for the bypass system so you can winterize.
There are many drawings showing how this is done. If you can't locate the drawings. Send me a PM with your email address and I will send you drawings.
Thank you for all your help ,
I have installed the water tank and it is new and installed plastic fittings to the Pex Pipe , but I have a issue the bottom line fitting has a steady drip ,
I did use the white tape on the treads and it continued and took it off reinstalled and it still drips ,
should I just replace the male fitting again with a new one ?? not real sure were to go from here all parts and tank were brand new and no the treads were not cross treaded , I was very carful on the install.
Need some help please
thank you all
So now I'm finally installing my Furnace - Suburban w/ the Stainless Steel Cover/Cap/Trim that goes on the exterior (for the combustion air intake and the combusted air exhaust). Again, similar to the water heater in my original post, the furnace has to be angled up a couple of inches so the outside trim/cap will slide in tight against the skin.
I didn't find anything in the literature saying the furnace must be level to operate but I wanted to find out if anyone knows for sure. And are your floor mounted furnaces installed level? Or are they angled?
Thanks.
Also, the literature points at the top "lip" of the exterior trim piece and says, "provide sealant" . . . I'm assuming this trim piece will get fairly hot - can I use Trempro/Vulcom Or do I have to find something designed for "heat"?
Thanks.
Mark, I appreciate your CAD drawing. That is some great work! I have a small problem with my water heater install. There are no water lines in the trailer, now, so I have no example to rebuild the system from. Where can I find a complete schematic for the water system in a 78 Argosy Minuete? Any help is appreciated.
Not an expert at water systems, and didn't create these diagrams, and can't remember where they came from, so I can't give credit to the source - but they seem pretty comprehensive.
