Old 10-30-2014, 03:24 PM   #15
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
So now I'm finally installing my Furnace - Suburban w/ the Stainless Steel Cover/Cap/Trim that goes on the exterior (for the combustion air intake and the combusted air exhaust). Again, similar to the water heater in my original post, the furnace has to be angled up a couple of inches so the outside trim/cap will slide in tight against the skin.
I didn't find anything in the literature saying the furnace must be level to operate but I wanted to find out if anyone knows for sure. And are your floor mounted furnaces installed level? Or are they angled?
Thanks.
Also, the literature points at the top "lip" of the exterior trim piece and says, "provide sealant" . . . I'm assuming this trim piece will get fairly hot - can I use Trempro/Vulcom Or do I have to find something designed for "heat"?
Thanks.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 11-07-2014, 10:52 PM   #16
1978 Argosy Minuet 6.0 Metre
Athens , Georgia
Mark, I appreciate your CAD drawing. That is some great work! I have a small problem with my water heater install. There are no water lines in the trailer, now, so I have no example to rebuild the system from. Where can I find a complete schematic for the water system in a 78 Argosy Minuete? Any help is appreciated.
MIKO92 is offline   Reply With Quote
Old 11-08-2014, 03:32 AM   #17
MarkR's Avatar
1960 24' Tradewind
Folsom , California
Images: 12
Not an expert at water systems, and didn't create these diagrams, and can't remember where they came from, so I can't give credit to the source - but they seem pretty comprehensive.
ID:	225988   Click image for larger version
Old 11-09-2014, 11:32 PM   #18
Athens , Georgia
Water Diagrams
Thank you! This makes it so much easier to understand and visualize.
