Old 01-09-2014, 10:41 AM   #1
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Water heater Indicator light
The water heater on my 07 25' FB International CCD works fine. My question is: When I flip the on switch the red light internal to the switch lights up and as soon as the propane is lit it goes off. The Heater heats the water in an appropriate manner. On my past AS the light remained on as long as the heater was functioning. Is it possible that the design has changed?
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 01-09-2014, 10:46 AM   #2
2012 27' FB Classic
yakima , Washington
I think so. Our old trailer an SOB had a light that stayed on. Our 2012 27FB does not stay on. It will go out after the water tank is heating.
We would prefer that it stays on but we have learned to live with it.
Mike and Gloria is offline   Reply With Quote
Old 01-09-2014, 10:47 AM   #3
twobikes's Avatar
1997 25' Safari
Montgomery , Alabama
Yes, it's working properly. If the little red light stays on, recycle a switch, you'll hear it try to start again, usually a little por, then the I'm working sound, mine sometimes takes a try or two. If it gets stubborn, there's a procedure in your owners manual outlining how to get a little airspace in the heater tank.
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at http://airgo.blogspot.com
twobikes is offline   Reply With Quote
Old 01-09-2014, 10:54 AM   #4
daveswenson's Avatar
2012 28' International
Issaquah , Washington
That's how it's supposed to work. If the light stays on the gas failed to ignite after three tries. Cycling the switch will reset it.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 01-09-2014, 11:27 AM   #5
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
Thank you one and all. I feel better now that I know it is functioning correctly. This is a great forum.
Keep the dirty side down,
Old 01-09-2014, 11:45 AM   #6
1974 Argosy 20
Kooskia , Idaho
Another note on the red light on the switch. I have had several DSI hot water heaters and all of them had the red light which went on for about a second and then went out when the burner lighted.
On my new 2014 FC, the red light is just a tiny flash, so quick it is even difficult to see after I turn the switch on. It is not the one second + light that I had in older units, so again things seem to have changed even further.
Old 01-17-2014, 07:56 PM   #7
AIR #6370
hmsteader's Avatar
2001 27' Safari
Bella Vista , Arkansas
Active water heater indicator
I did a little tinkering job on my previous and my present Airstreams. After removing the water heater access panel in tne bathroom and probing with a multimeter checking for 12vdc on the different contact points, I added a small 12vdc LED to indicate when the water heater is active. The job is not difficult, but caution must be used as insulated leads must be extended by soldering on the LED.
hmsteader is offline   Reply With Quote
Old 01-18-2014, 03:43 AM   #8
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
hmsteader,
Would you have a picture of your installation?
>>ron<<
Old 01-18-2014, 03:47 AM   #9
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The indicator light on my water heater switch just sorta blinks when you turn on the switch. Water heater works fine. Another question for the mother ship.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-21-2014, 10:16 AM   #10
AIR #6370
hmsteader's Avatar
2001 27' Safari
Water Heater Indicator Light
Carver1: Ron, I'm going to attempt to add a few photos of the 12vdc LED monitor indicator that I've installed. I hope this works for you.
Name:	01 Water heater off.JPG
ID:	204105   Click image for larger version
Name:	02 Ignition with monitor indicator.JPG
Name:	03 System monitor on.JPG
ID:	204107   Click image for larger version
Name:	04 Rear of water heater panel.JPG
Name:	05 LED leads.JPG
ID:	204109   Click image for larger version
Name:	06 LED leads continued.JPG
