Old 09-13-2012, 11:58 AM   #1
Old School Young Gun
ElCamino Man's Avatar
Olney , Illinois
Water Heater In/Out
Hey guys! I am knee deep in plumbing my AS and its going a whole lot smoother than I figured! Especially for being my first plumbing job
Anyways, the only 2 things I havent plumbed in yet are the toilet and water heater. Toilet because its not bolted down yet and the water heater because i am unsure which side is the "in" and which side is the "out". Mine has a hose on top and one on bottom. If I was guessing, Id figure the bottom is in and the top is out. Can anyone confirm this?
No Airstream Yet...
ElCamino Man is offline   Reply With Quote
Old 09-13-2012, 12:04 PM   #2
Kevin245's Avatar
Your guess is correct.
Lower for the inlet.
Upper for the outlet.
Eleanor Roosevelt
Old 09-13-2012, 02:00 PM   #3
Ottawa , ON
You live in Illinois: don't forget to put a by-pass hookup on that WH!
Old 09-13-2012, 03:17 PM   #4
Olney , Illinois
A bypass hook up... Im not sure what that is lol
No Airstream Yet...
Old 09-13-2012, 07:08 PM   #5
Splitrock's Avatar
Sioux Falls , South Dakota
This is how I did my bypass.
They can be bought ready to go as well.
Old 09-13-2012, 07:42 PM   #6
1981 31' Excella II
New Market , Alabama
Looks pretty complicated. I don't like the plastic fittings. What does the bypass do beside feather pockets of the plumbing supplier?
Perry
Old 09-13-2012, 07:48 PM   #7
1977 Argosy 24
Milltown , Wisconsin
The bypass takes the water heater out of the hot water loupe, so when you winterize the AS you don't need 6 gallons of antifreeze to fill the water heater. Then you just drain the water heater. You can then fill all the pipes with about 2 gallons of antifreeze instead of 8 gallons.
ventport is offline   Reply With Quote
Old 09-13-2012, 08:17 PM   #8
eubank's Avatar
1967 30' Sovereign
Bosque Farms , New Mexico
I built a bypass set-up similar to what Splitrock shows in his pic -- and ran into a slight problem with it. Last fall, I emptied the water heater tank, then turned the valves to exclude the water heater for the pink stuff. Seemed to work great, but when I took the rig out this summer, I found that one of the connectors within the bypass had split. Argh. Turns out, I guess, that a small amount of water was trapped within the bypass for the winter, and, given sufficiently cold temperatures (-30F), it split the connector.
Not exactly a difficult repair job, just a quick trip to the hardware store and a few minutes of labor. But I will remember to push just a little pink stuff through those lines this year.
Lynn
WBCCI 21043
Old 09-13-2012, 08:27 PM   #9
Central , Mississippi
Originally Posted by ElCamino Man View Post
Hey guys! I am knee deep in plumbing my AS ... the only 2 things I havent plumbed in yet are the toilet and water heater...
I've actually seen one camper that goofed up and had hot water plumbed to the toilet...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 09-13-2012, 08:35 PM   #10
Splitrock's Avatar
Wouldn't that be . . . goofed down?
Old 09-13-2012, 09:09 PM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The bypass system consists of 3 valves. 1 to prevent cold water from entering the water heater. 1 in the hot water line coming out of the water heater. 1 in a line that connects the hot and cold water lines together down stream from the 2 valves mentioned above.
When you winterize, you close the valves on the inlet and outlet of the water heater and open the valve that ties the hot and cold lines together. Drain the water heater. And pump RV anti freeze into the lines. Now you are set. Make certain you put RV anti freeze in the "P" traps for the sinks and shower/tub.
RV anti freeze should not be put in the water heater. It tends to become rancid and it is hard to get rid of the rotten egg smell.
Old 09-13-2012, 09:29 PM   #12
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I don't go the RV antifreeze route. I blow the lines with compressed air. In my '85 Excella I did not have the by-pass so I simply drained the water tank and blew the water out of the lines. Our newer trailer has the by-pass. Will it be sufficient to turn the by-pass valves then drain the tank and blow the lines ????
Or is there something else to do ??
Thanks all
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 09-14-2012, 08:42 AM   #13
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
As long as you feel that enough water is blown out of the lines to prevent freeze damage. But it is difficult to tell if all water in the low points is removed. By pumping RV anti freeze thru the lines until you see it coming out of all of the faucets and into the toilet you will know the lines are winterized. You also need to put anti freeze in the "P" traps of the sinks and shower/tub.
Old 09-14-2012, 08:57 AM   #14
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Thanks all
My local dealer uses air pressure only to winterize. He does use high pressure to blow out the lines and keeps the air flowing to make sure the lines dry out. He noted that most 12 volt compressors cannot generate enough airflow to dry out the lines. I blow mine out and then pump in antifreeze through the water pump. It takes less than 2 gallons for my Classic which includes enough antifreeze to pour directly into the drains to make sure the traps are protected. In the past I used to take a shop vac and reverse the airflow and put the blowing hose into the drain and push the water out prior to adding the antifreeze.
Depending on your model trailer (some have these features and some don't), don't forget to winterize the hand sprayers on the sink and toilet, the outside faucet valve, and the low drain points (hot and cold) that tend to be under the trailer. All of those can be forgotten and can freeze up.
Jack
Jack Canavera
STL Mo.
AIR #56
