Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 09-03-2003, 05:43 PM   #1
srae
Profile:
Water Heater HELP!!!
I've left my electric on to my Land Yacht Airstream but turned off the water and gas. I have forgotten to turn of the switch for the electrical ignition. Will this cause a problem?
srae is offline   Reply With Quote
Old 09-03-2003, 05:46 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Only if you count a dead battery as a problem
The water heater will try to light a few times and should stop. If it re-tries it will just give up again. The heater is a 12 VDC device, right? If it is a 120 Volt device it will have been shut off when you turned off the power.
Absolute worst case, you could burn out the ignightor system, but I doubt it.
I just re-read your post. The univolt will keep the battery up, so the water heater will just keep retrying. I do not know how long it tries before giving up.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 09-03-2003, 05:49 PM   #3
srae
Profile:
It's plugged into the 110 current, and it's got the 12 Volt back up. I'm really worried. I could contact the location it's parked at and have them unplug it totally.
Is there any way to chat directly with you? I'm new to this location and new to the Airstream world!
Old 09-03-2003, 05:53 PM   #4
thenewkid64
Just a member
Images: 21
We can go to the chat room!
Click on the forum button at the top of the scren and the on the Airstream Caht link 2 or 3 down from the top. Log in and I will be there.
You have to be paitent for the chat to load
Brett G
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 06:16 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 11:29 AM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 06:37 PM
Water Heater Advice! John Sims Water Heaters, Filters & Pumps 1 06-16-2003 09:43 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 08:26 AM
