Old 04-07-2009, 06:15 PM   #1
tdoescher's Avatar
1969 31' Sovereign
Madison , Wisconsin
Water Heater for Airstream 69 Sovereign
Just purchased a Airstream, 69 Sovereign the water heater was removed since it did not work, anybody know of a good replacement that would fit in with easy installation? Thanks
tdoescher is offline   Reply With Quote
Old 04-07-2009, 07:33 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
An Atwood 10 gallon LP only model would fit in the hole, and be the most economical, as well as easiest to install. You'd only need an LP line and the water lines. All the other stuff needs 12 volt for DSI, or 120 volt for electric elements, or both.
Old 04-07-2009, 08:24 PM   #3
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
If I had a choice and $ was no object... I would find a small on demand hot water heater... That way I could actually take a shower where I could get wet!
Mrs. NorCal Bambi traveling in S Tardis ~ from the Great State of Jefferson!
My blogs: http://yrekahistory.blogspot.com
http://siskiyoucountycamping.blogspot.com
http://campingalongi-5.blogspot.com/
CaddyGrn is offline   Reply With Quote
Old 04-08-2009, 01:38 AM   #4
nkeeler's Avatar
1977 23' Safari
Prince George , British Columbia
i was thinking about a tankless water heater for my 63 overlander but was unsure as to the size that i would need.
Any advice?
nkeeler is offline   Reply With Quote
Old 04-08-2009, 06:10 AM   #5
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Any advice?
I have been looking at the RV-500 on demand How Water Heater there like 1000 bucks new AND not sure how much installation modification you need to do . Actually that is what I need to know is if i need to do any modification on my 31 foot 1977 Sovereign international rear bath and rear installed Hot water heater if I install the RV-500?
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Help, no hot water heater bypass in my 1975 31' Sovereign ShinyTwinkie Winterizing, Storage, Carports & Covers 5 11-30-2008 05:52 PM
water heater 72 sovereign, info please acanthus Water Heaters, Filters & Pumps 3 09-25-2008 05:51 PM
HELP '78 Sovereign - Disassembly of Center Bath Interior for Water Heater Replacement 87MH General Interior Topics 3 02-28-2007 06:32 PM
Water heater recommendation for a "landed" Sovereign? davida Water Heaters, Filters & Pumps 3 07-22-2006 07:50 PM
72 sovereign....which water heater? Need help soon! 72sovrn Water Heaters, Filters & Pumps 1 02-04-2004 07:11 AM
