Old 09-26-2013, 10:05 AM   #1
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Water heater-electric/Propane combo?
Investigating replacing my water heater and am considering the basic drop-in Atwoods. Im looking at the basic propane model vs. the propane with the additional electric heating element (WATER HEATER ATWOOD - GC6AA-8). I saw one post recently where someone bought the electric combo model, and said if he had it to do over again, he would go propane only (because they never use the electric). Anyone else had this experience? Any compelling arguments for/against the electric/propane model?
Old 09-26-2013, 10:21 AM   #2
1974 Argosy 20
Kooskia , Idaho
If you boondock without hookups the electric one is more or less useless. That is the way I travel, so when I put a new DSI water heater in my Argosy, I went with propane only. My new FC has the electric element in it as standard equipment but since I am rarely plugged in to power it remains mostly unused.
Those who stay in campgrounds with power like the electric element as it is "free" heat for their hot water. Of course they pay for it in the campground fee as does everyone else.
So, depends on your travel mode.
Old 09-26-2013, 10:41 AM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
My Classic came with the electric/gas unit and I really have been pleased with it. We always camp where there is electric so the savings in gas is great. The other benefit is that we can click on the gas side of the heater when showering which provides much more hot water. It is especially noticeable when we camp in the early/late seasons or at sites that have cold water supplies such as northern Wisconsin or Michigan.
The disadvantages can be at sites that have weak circuit breakers when you attempt to run microwave, air conditioner and water heater at the same time. Not a frequent occurrence but it happens at least once a year at a campsite. In that case we switch off the electric to the heater during those high use periods.
I guess the other disadvantage when you are doing a replacement in a trailer that hasn't had a dual fuel heater is the electrical wiring and the switch that needs to be added. If you aren't handy in that realm, it might be better to install a gas only unit.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-26-2013, 11:02 AM   #4
1977 Argosy 24
Milltown , Wisconsin
I have an Atwood LP/electric water heater, and when my ignitor/senser went out at a campground, I was still able to have a hot shower due to the electric mode still working. Now I use it on electric whenever we have power, saving my LP for when we boondock. Plus on electric it is silent, so you will not wake up to the roar of the LP burner.
ventport is offline   Reply With Quote
Old 09-26-2013, 11:26 AM   #5
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Always Give Yourself Options
Whenever I re-equip or restore a vintage Airstream, I try to take advantage of new technologies.
The propane/ electric combo water heater is a wonderful improvement over the original, propane-only water heater that came with your 1973.
Whenever we have hookups we heat our H2O with electricity and conserve our propane. When we boondock we use propane.
The Atwood propane water heater with electric option is just as easy to install as one without electric. The cost difference is negligible.
As a separate but related recommendation, please be sure to install water heater bypass valves and line when you install your new water heater. It is easily done and makes winterizing so much easier.
Hope this helps.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 09-26-2013, 12:50 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
Having an electric option available adds a little weight and a little cost -- not much of either. Other than the weight and cost, there's no disadvantage to having electric available. If you don't want to use it in any particular situation, you just turn it off.
My Airstream has an electric/propane water heater while my Cayo has propane only.
The electric/propane setup has several advantages:
1) If you camp where there is electricity, you end up using much less propane. I typically refill one of the 40# propane bottles on the Airstream once a year, maybe more if we're doing a bunch of winter camping. The Cayo has 20# bottles, and for the same amount of camping, I refill them 5-6 times. My local propane dealer wants the bottles dropped off, they fill them then I pick them up the following day. It makes for a lot of extra errands, in addition to the cost.
2) The water heater is quieter when it is set for electric operation.
3) During busy times when you're using a lot of hot water, you can run both the gas and electric, and the water heats faster than with gas alone.
4) If you're ever in a situation where you park your rig inside a garage or other enclosed space, you can run the electric water heater without concern about CO from the water heater exhaust accumulating.
5) Aside from the general cost and hassle of getting propane, electric is particularly suitable if you, at some future point, are camping in a remote location with poor or seasonal road access so that you have to hand-carry propane, or where there are no propane dealers nearby, etc. Since it is generally not possible to retrofit an electric element to a water heater (kits like the hot rod have many drawbacks compared to the factory setup), you're better off planning ahead now.
Old 09-26-2013, 02:13 PM   #7
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
We upgraded our 65 Safari with an Atwood DSI Elect/Propane water heater this spring. We love it! We boondock 70% and in parks 30%. Always use the elect. in the parks. If you shop around the elect. option is not much more $ and well worth it. It will be a plus if you should sell your trailer down the road.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 09-27-2013, 07:43 AM   #8
Belegedhel's Avatar
Houston , Texas
Thanks everybody--this was the kind of feedback I needed!
Old 09-27-2013, 08:08 AM   #9
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
X2
Disclaimer....we have never been "hooked-up"
We seldom use electric, (except when the switch is whacked on by mistake),
or it's turned on at Spring get-ready.
We conserve LPG by only running the burner when hot water is needed, 20min and it's plenty hot with these new tanks with no thermostats. When not at the CS, it's off.
Plus we sprung a line leak at night, cold water in the tank kept the burner on, we discovered it at 5am. Ticking pump and roaring burner make a rotten alarm clock. Lucky the tank hadn't pumped out.
Nice cross-threaded fitting.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 09-27-2013, 08:52 AM   #10
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
It can't hurt to have the choice available, the need depends on type of travel and camping you do. We spend months at a time in our Airstream, probably best described as destination campers. We decide where we want to spend some time, boondock most of the time along the way using only solar and propane, and electrical hookups when we get there. Nice to have it either way.
Doug and Cheryl
