Old 05-27-2019, 01:47 PM   #1
2018 25' Flying Cloud
Bristow , Virginia
Water heater draining
Am I the only one who drains the water lines and water heater during short or in between trip storage periods? No other reason than stagnant water concerns not weather or freezing concerns at all. Is this a bad practice? Are there any downsides to doing this?
Gooch is offline   Reply With Quote
Old 05-27-2019, 01:53 PM   #2
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I also drain the WH most of the time.
SSquared is offline   Reply With Quote
Old 05-27-2019, 02:51 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We always drain everything at the end of a trip, no matter how soon we're going back out.
Kay
Old 05-27-2019, 02:55 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I only my drain end of season. We do 30-40 nights per year so water typically doesn’t stay in the tank more than 30 days or so before getting used for showers or dishes.
wulfraat is offline   Reply With Quote
Old 05-27-2019, 04:01 PM   #5
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
.......good idea
Old 05-27-2019, 04:37 PM   #6
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Do you use a drain valve like this
Name:   RV DHW Drain Valve.jpg
or remove the plug.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 05-27-2019, 05:24 PM   #7
2017 27' Flying Cloud
London , Ontario
Does that brass part replace the nylon plug? I would drain my WH after each trip but it too much of a hassle.
27FB 2017 Flying Cloud
F-150 Lariat
Ham Radio Callsign - VA3PGJ
Philip Jones is offline   Reply With Quote
Old 05-27-2019, 05:55 PM   #8
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
We bought our trailer from Colonial, and they recommended that we drain the water heater if the trailer was going to sit more than a couple weeks between trips. I've since drained it and the fresh water tank after almost every trip.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 05-27-2019, 06:36 PM   #9
The brass petcock replaces the nylon plug. To drain effectively you need to open the pressure relief valve at the top to let air in because the petcock is quite small diameter.
Ray B.
Old 05-27-2019, 07:24 PM   #10
Kevin245's Avatar
We drain our WH at the end of each camp regardless. Just a housekeeping thing of mine. I installed a mini ball valve on ours several years ago. A simple 90 degree turn to drain.
Eleanor Roosevelt
Old 05-27-2019, 08:39 PM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I installed a boiler cock on the Atwood water heater. Turn the handle 90 degrees. It is not the same as pulling the plug but better than the petcock shown above. Also open the pressure relief when draining.
I drain the water heater and fresh water tank at the end of every trip. Along with the holding tanks.
Old 06-01-2019, 04:59 PM   #12
London , Ontario
TG Twinkie: any way you could post a photo/link to purchase? Thanks.
F-150 Lariat
Old 06-02-2019, 07:16 AM   #13
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Check your private messages
Draining Water Heater MarkBeck Water Heaters, Filters & Pumps 5 01-02-2019 12:27 PM
Water heater draining root4wings Plumbing - Systems & Fixtures 3 10-28-2018 04:34 PM
Draining water heater? Will_Brule Water Heaters, Filters & Pumps 20 09-21-2013 04:16 PM
draining water heater John Greenlee Winterizing, Storage, Carports & Covers 15 12-30-2005 03:04 PM
Electric water heater element: Draining dilema rfield54 Water Heaters, Filters & Pumps 4 05-19-2005 10:07 PM
