Old 01-12-2019, 02:04 PM   #1
wmb
2013 25' Flying Cloud
Springfield , New Jersey
Water heater drain plug dripping even with a new plug
The old plug has been dripping very slowly for a couple of weeks, so today I decided to fit a new one. I used about 3-4 turns of white Teflon tape on the plug and made it finger tight + 1/2 turn.
I still dripped slowly.
I noticed that there's a bit of calcified crud around the end of the pipe, so I scrubbed off what I could with an old toothbrush and a few drops of CLR, then ran cold water through to flush it out, and tried again with the new plug and another 3-4 turns of Teflon tape.
It's still dripping (and seems to be dripping a little faster than before).
What do you think I should try next?
wmb is offline   Reply With Quote
Old 01-12-2019, 02:13 PM   #2
Long Island , New York
Hooked up to city water . . . [shut off at first] . . .
The female threads which receive the plug probably have calcified crud in them IMO. I would drain the water heater, and use a small round brass wire bottle brush to clean those threads. Then use a tap [NPT -- with cutting oil] to chase out the threads. Flush well with lots of city water.
Should do the trick IMO. If not, use more Teflon tape and a correctly-sized socket wrench to install the plug. If the plug is nylon it is hard to do damage to the water heater IMO.
Any chance you damaged the threads with previous cleanings?
Good luck,
Peter
PS -- Sounds like your water has been hard, so you might want to also get a new PRV for the top of the water heater. They get crudded up all the time from hard water. [pressure relief valve] Usually a generic valve easily purchased at most hardware stores.
Old 01-12-2019, 02:50 PM   #3
Edistobob's Avatar
Edisto Island , South Carolina
I think you'll have better results with the old - fashioned pipe thread compound in a tube vs the Teflon tape. Just be sure to use the kind formulated for both metal and plastic vs single-use. I've had the same issue as you and have never had a leak after using the pipe "dope".
Edistobob is offline   Reply With Quote
Old 01-12-2019, 03:05 PM   #4
2006 34' Classic S/O
1994 28' Excella
1950 18' Clipper
Elgin , Texas
Note: whatever you do...be careful with the threads in the tank. It's aluminum and fairs poorly if damaged. I do agree to using a new nylon plug (they're cheap) with pipe thread dope as a helpful sealant and use a socket wrench not a adjustable wrench to screw it in.
Make sure it's threaded properly and seated deep enough. Hard to work around all the tubes/wires etc with an adjustable wrench.
Good Luck & Safe Travels.
Ol Bob is offline   Reply With Quote
Old 01-12-2019, 04:52 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
Tape and dope on a new plug would be where I went next
CRH is offline   Reply With Quote
Old 01-12-2019, 07:13 PM   #6
2019 30' International
Pennsylvania , Pennsylvania
finger tight and half a turn, likely not spun tight enough.
majorairhead is offline   Reply With Quote
Old 01-13-2019, 11:59 AM   #7
1976 31' Excella 500
Chappell Hill , Texas
Plumber here. Major airhead is correct. Probably needs to be tighter. If male and female threads are cut correctly then threaded fittings will have approximately 2 1/2 threads left showing when properly tightened. Never use plastic or nylon on hot water. I suggest a brass drain cock rather than a plug too.
tbashin is offline   Reply With Quote
Old 01-13-2019, 01:50 PM   #8
Okstreamer
2007 25' Safari FB SE
Yukon , Oklahoma
Another plumber here, and I agree with previous post, get rid of the plastic plug, it has different thermal growth characteristics than the surrounding metal. My plastic plug started leaking and I just replaced with a brass plug and small amount of pipe dope . No more leaks.
okstreamer is offline   Reply With Quote
Old 01-13-2019, 03:35 PM   #9
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Per Suburban.... The nylon plug is not just a plug... It is a safety feature. It is designed to fail out if the temperature exceeds a set limit. This is different than the pressure relief valve. The genuine plugs are different than the aftermarket junk Camco plugs!
The genuine Suburban plugs also have tapered threads.
Old 01-13-2019, 03:50 PM   #10
. . . moreover the plastic plugs offer the benefit of making it basically impossible to mess up the female threads in the aluminum water heater, which the typical layman non-plumber might do with a brass or steel plug etc..
Easy enough to carry extras or get them on the road.
Old 01-13-2019, 09:24 PM   #11
CRH
1995 25' Excella
xxxxx , xxxxxx
I don't have a Suburban WH. Mine is an Atwood. The junk Camco plugs work fine in it.
Old 01-14-2019, 06:47 AM   #12
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Another (nuclear) plumber here:
GOOD
OEM plug, they picked it for a reason.
thread dope, from plumbing supply
Socket and handle not in constraints
Start by hand tight, then snug up, less than gorilla or star torque
NOT AS GOOD
Some other plug, maybe stronger material than the base threads
Teflon tape used thinking it seals threads, vice lubricates
Can buy plastic bushings that you can fabricate your own drain cock. Those aluminum threads aren't very robust to take cross threading and recutting.
Ain't it just the winky stuff that drives you crazy?
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 01-14-2019, 08:49 PM   #13
Denver , Colorado
As others have mentioned, I’d recommend pipe dope in a tube vs tape. I had the same problem, and this did the trick.
Also great idea with socket vs adjustable wrench. In a pinch I had to use the adjustable once (and before I used the pipe dope), and the hex head of my plug is a bit more ’rotund’ as a result.
Jump, and the net will appear.
Papatango is offline   Reply With Quote
Old 01-14-2019, 09:04 PM   #14
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
OK..Another plumber here, lol. I'd go with the nylon plug for reasons mentioned and my new go to thread sealant , blue monster tape, cost 4 times as much as typical teflon tape but the stuff is magic. Agree that you are not tight enough if its still dripping, assuming the tapped bung is not compromised anyway.
good luck.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Water heater dripping at outside access panel Hikesail Water Heaters, Filters & Pumps 10 10-27-2018 04:02 PM
Water dripping from copper drain pipe.... Mx468 Water Heaters, Filters & Pumps 9 08-31-2018 03:10 AM
Atwood water heater dripping mmich21 Water Heaters, Filters & Pumps 10 12-01-2016 03:18 PM
water dripping from hot water heater access panel groundhogy Water Heaters, Filters & Pumps 5 06-01-2015 11:21 AM
Grey water indicator is yellow even tho drain is open CalamonTin Our Community 2 05-25-2014 08:51 PM
