Old 03-15-2016, 04:42 PM   #1
2017 27' Flying Cloud
Matthews , North Carolina
Water heater drain plug
Anyone know what size socket to use to unscrew your water heater drain plug? It's for a 2015 23D. Thanks
OARfan is offline   Reply With Quote
Old 03-15-2016, 06:22 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
15/16 open end fits mine. There is not room to get a socket on it. Gas line is too close.
MICHAEL
Old 03-15-2016, 07:01 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
It is a plastic plug that easily gets scuffed up from use. It is a common "pipe fitting" available at your local hardware store. I replace mine every two years or so. My 15/16 open end wrench is what I use.
I think Rich Luhr's Guide to Airstream Maintenance is a great resource for us Airstream owners. He discusses this water heater plastic plug as well as maintaining the water heater burner. I found his booklet is a great reference. It is available at the Airstream Life store on line.
David
Old 03-15-2016, 07:44 PM   #4
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Agree on the 15/16 size. I use an adjustable wrench to install/remove plastic plug. I always carry, in my emergency bag, a couple news plugs along with a roll of teflon tape, to wrap the threads to create a tighter waterproof seal.
tsunami is offline   Reply With Quote
Old 03-15-2016, 07:50 PM   #5
Thanks for the reply's amigos! I was scuffing the heck out of it myself trying to tighten it with a wrench.
Mark
Old 03-16-2016, 10:51 AM   #6
2014 27' Flying Cloud
Stowe , Vermont
I have always been able to use my ratchet socket WITH a 6 inch extension. Fits in well and doesn't touch the gas line.
VT Wanderer is offline   Reply With Quote
Old 03-16-2016, 10:52 AM   #7
2014 Interstate Ext. Coach
fairfax station , va
alternate plug
Sorry I can't remember/credit the OP who used a flush brass plug.
http://goo.gl/wJjcZK
It's the bee's knees when you have a hex key drive and extension for your ratchet
http://goo.gl/xxD0B9
No more tight space/access problem
VAtom is offline   Reply With Quote
Old 03-16-2016, 12:22 PM   #8
1996 25' Excella
Tillsonburg , Ontario
I have found a short extension allows me to use the socket wrench. I keep a 3/8 drive extension with socket in the tool box and use an adjustable to turn the jig if I don't have the rat chest available.
JCW
JCWDCW is offline   Reply With Quote
Old 03-16-2016, 12:35 PM   #9
Lily&Me's Avatar
Normal , Illinois
I have tightened and untightened mine with needle nosed pliers.
Maggie
Old 03-16-2016, 12:48 PM   #10
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
There is a tool available at Camping World for this application.I have one.
Old 03-16-2016, 01:07 PM   #11
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
Water Heater Drain
Two 45 degree Street Ells and a turn Boiler Valve. Attach hose, drain into container.
No tools, no cross-threads, no spare plug, no spills, effortless...
BTW, If you worry that the dissimilar metals will ruin your tank, go Tale with the Old Wives, or replace first Street Ell with stainless nipple and then elbow...
This is a great "work-around" that can be configured to suit various conditions.
ALUMINUMINUM is offline   Reply With Quote
Old 03-16-2016, 03:22 PM   #12
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Flush & drain....
ID:	258881   Click image for larger version
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-16-2016, 04:38 PM   #13
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Question Needle nose pliers?
Maggie
HOW???????
MelGoddard is offline   Reply With Quote
Old 03-16-2016, 04:44 PM   #14
15/16th.???
I've successfully NEEDED a 1" socket 6 point on an 8" extention to remove/install the plug.
It's a short socket that just clears the gas line.
hot water heater drain plug gpt Plumbing - Systems & Fixtures 30 11-11-2015 03:29 PM
Water Heater Drain Plug Broken earlwalker General Repair Forum 29 07-16-2015 11:01 AM
Water heater drain plug - 2005 Classic 30 Wingeezer Water Heaters, Filters & Pumps 5 09-15-2012 06:32 AM
Atwood water heater drain plug nm1oqrz Water Heaters, Filters & Pumps 33 05-14-2011 09:30 AM
Bowen B10G water heater drain plug lebolewis Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-20-2008 11:49 AM
