Old 03-16-2016, 05:26 PM   #15
Long Island , New York
Originally Posted by OARfan View Post
Anyone know what size socket to use to unscrew your water heater drain plug? It's for a 2015 23D. Thanks
Having a good socket set (up to 1") is a good tool for any trailer to have, and would cover the socket you need plus assorted extensions, as mentioned already. Can't imagine going on the road without such a set, plus many other tools.
PS Maggie, really? Surprised you could loosen the drain plug at all, without rounding off the corners mercilessly!
Old 03-16-2016, 05:47 PM   #16
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I did a slightly different approach, after removing the plastic plug I got a petcock and a reducing bushing. Installed and now it just takes a turn and it drains. If you aren't familiar with a petcock, look at your hot and cold water low point drains, petcock.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 03-16-2016, 08:24 PM   #17
1998 30' Excella 1000
Livingston , Texas
Originally Posted by MelGoddard View Post
15/16th.???
I've successfully NEEDED a 1" socket 6 point on an 8" extention to remove/install the plug.
It's a short socket that just clears the gas line.
Ran into the 15/16" and 1" problem myself. Turned out one size was an OEM Atwood plug, the other an aftermarket plug sold in many RV parts stores.
Siegmann is offline   Reply With Quote
Old 03-16-2016, 11:18 PM   #18
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
Originally Posted by ROBERT CROSS View Post
Flush & drain....
Hey Bob, is that an air line connected to the PRV in the first image? When you winterize do you also pressure up from the PRV connection as well as the city water?
My experience is that's a bit of a challenge getting all the water out of the WH even with the plug removed, when pumping from the CW connection. I expect this connection may help.
p.s.to remove the plug I use a socket with a 6" extension and the teflon in a tube. Th socket allows for a straight shot connection to the limited surface if the plastic plug. I'm thinking of converting to a brass NPT plug.
CruizinDux is offline   Reply With Quote
Old 03-17-2016, 03:05 AM   #19
Lily&Me's Avatar
Normal , Illinois
Needle nosed pliers were what I could get in there.
Maggie
Lily&Me is online now   Reply With Quote
Old 03-17-2016, 04:33 AM   #20
Using a plastic plug with teflon tape ensures that no damage can be done to the water heater's internal female threads. Extra plugs are inexpensive to have on hand.
Keep It Simple Stu . . .
Old 03-17-2016, 04:34 AM   #21
Maggie
Gotcha, sorry AS made it so inaccessible on your Interstate! Hope you carry a spare plug or two . . .
Old 03-17-2016, 04:46 AM   #22
As the last step of winterization (using air to blow out all the lines), you can blow out any water remaining in the water heater with the drain plug removed and PRV closed. Any small amounts of water still at the bottom of the heater will come out, even if they might not have by gravity alone IMO. [with all other faucets etc. closed]
Old 03-17-2016, 05:21 AM   #23
Lily&Me's Avatar
Normal , Illinois
I do carry a spare plug, as you don't pick one of these up just anywhere.
One of those things that should be in all of our tool kits.
Maggie
Old 03-17-2016, 06:32 AM   #24
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I find them at any hardware or plumbing supply store.
2012 Dodge Durango Hemi/AWD
Old 03-17-2016, 06:37 AM   #25
Lily&Me's Avatar
Normal , Illinois
We've had trouble finding the right size, even in a hardware store....recall a nice young man in Natchitoches, LA, taking us from his hardware store to a plumbing supply place....where we bought 2.
If one is in rural America, it is good to have an extra on hand.
Maggie
Old 03-17-2016, 07:20 AM   #26
Anna , Texas
I use a 15/16" flexible ratchet wrench I found online for $20:
Name:	ImageUploadedByAirstream Forums1458220669.020429.jpg
The adjustable head lets me clear the bit of duct right above the plug:
Name:	ImageUploadedByAirstream Forums1458220808.290124.jpg
kcollins is offline   Reply With Quote
Old 03-17-2016, 07:20 AM   #27
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Bob,
Yes..... the MacGyver set-up uses air to help purge the tank. Look close...you can see that the nozzle is wired open. The compressor in the garage can supply a steady 30psi to help clean the tank.
I do use it to purge the supply lines when Winterizing....you can see the white CW connector.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
ďItís a crooked piece of time that we live inÖ.Ē
John Prine
Old 03-17-2016, 09:35 AM   #28
CruizinDux's Avatar
Thanks Bob. Looks like it's an easy setup. I may go in that direction. The last winterization I had to continually turn the fwd LP drain on/off, to get the last of it out. Not sure if it was in the tank or the line. With the new LP drains at the end of the line (vs in line) and the change to gravity flow, I'm hoping this will correct the issue.
hot water heater drain plug gpt Plumbing - Systems & Fixtures 30 11-11-2015 03:29 PM
Water Heater Drain Plug Broken earlwalker General Repair Forum 29 07-16-2015 11:01 AM
Water heater drain plug - 2005 Classic 30 Wingeezer Water Heaters, Filters & Pumps 5 09-15-2012 06:32 AM
Atwood water heater drain plug nm1oqrz Water Heaters, Filters & Pumps 33 05-14-2011 09:30 AM
Bowen B10G water heater drain plug lebolewis Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-20-2008 11:49 AM
