Old 12-12-2014, 12:52 PM   #1
kenen42's Avatar
2011 27' FB Flying Cloud
Delmar , New York
Water Heater Drain Line?
When I was winterizing my new to me 2011 FC 27FB I found a drain line connected to the cold water inlet line of the water heater, just before the bypass valve, that goes through the floor and comes out through the belly pan. No mention of it in the manual and can't figure out what it's for. Too high up to be a low point drain and the cold water inlet appears to enter the tank to high for it to be useful as a tank drain. You can see it at the bottom of the attached picture. Does anyone know why it's there?
Name:	Water Heater.JPG
kenen42 is offline   Reply With Quote
Old 12-12-2014, 01:03 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
There was a thread on this a few weeks ago. I asked AS about it because I have one too. They told me it is a drain for an area that the low point drains do not drain.
Larry
lsbrodsky is offline   Reply With Quote
Old 12-12-2014, 01:30 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
It is a low point drain for the supply line to the water heater.
Drain and blow the all low point valves one at a time when winterizing.
The drain for the tank is on the tank, bottom left in the picture, the brass pet-cock.(replacing the OEM plastic hex plug)
The air line is connected to the pressure relief valve to help force the water out and flush any scale build-up in the tank itself
Old 12-13-2014, 11:06 AM   #4
kenen42's Avatar
Delmar , New York
Thanks, missed that thread. Glad I blew the water out of it when i winterized.
Low Point Water Line Drain Valves Froze! Dwellstream Fresh Water Systems 25 11-21-2014 11:10 AM
Pressurized Water Line Drain Petcocks Phil&Sher Fresh Water Systems 24 01-27-2014 01:06 PM
water coming out pressure regualtor drain line when on city water txstreamer Fresh Water Systems 7 09-16-2010 03:07 PM
Trouble hooking gas line to water heater 63air Water Heaters, Filters & Pumps 8 09-06-2005 09:56 PM
gas line to water heater bken Water Heaters, Filters & Pumps 0 05-03-2003 08:11 PM
