Old 08-30-2005, 10:50 PM   #1
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Water Heater Drain
Had anyone replaced the plastic drain plug on an Atwood water heater with a valve. It would make draining the tank alot easier.
Richard
Old 08-31-2005, 07:22 AM   #2
jimmickle's Avatar
2000 31' Land Yacht
I have done it. All you have to do is go to your favorite hardware store with the plastic plug. Get a reducer with the same outside thread and internal thread to fit a drain valve that they should also have. One concern with doing this is the compatibility of the brass and aluminum. It may cause the aluminum to corrode, ruining the tank. Mine was only in about a year before I traded the unit so I don't speak from experience. My current trailer, a 2002 safari, has a low point drain on the inlet line to the water heater. Opening it drains everything, including the heater. You might want to incorporate one in your unit. To me, it seems like the best way to go. Not as fast as pulling the drain plug and having water gush everywhere, but it drains the heater more completely.
Another alternative might be to drill and tap the plastic drain plug for a drain valve. You would probably want to tap for 1/4 pipe thread to have a course enough thread. I haven't done it, just an idea you might try on an extra plastic dtain plug.
jimmickle is offline   Reply With Quote
Old 08-31-2005, 07:28 AM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I'm not sure if you drain the tank frequently or not. I only do it once a year when I winterize. One of the benefits of pulling the big plug is that the sediment in the tank can easily exit. I then use my tank saver device to scour the tank internally and therefore remove any sediment that is stuck to the tank walls. Doing this annually will extend the life of your tank greatly.
Here is a link to the thread and the picture of the Tank Saver.
Tank Saver
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-31-2005, 07:37 AM   #4
2003 25' Safari
Eden Prairie , Minnesota
The plastic hot water heater plug is a bit difficult to get at, and rounds-off easily. I purchased a water heater tank drain valve (to replace the plug) from an RV dealer. I rinse the water heater with fresh water before each trip, and drain it after each trip. At the end of the year I remove the valve and flush out the tank with a plastic sprayer wand, sold at RV dealers for this purpose.
Dan
dmac is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
Water heater work tool FrankR Water Heaters, Filters & Pumps 1 04-09-2002 10:57 AM
