04-05-2018, 07:37 AM
Fr Jeff
1989 29' Excella
Saginaw
, Michigan
Water Heater Drain
Relatively new owner of 1989 Excella 29. Returning to Michigan soon from our winter abode and want to drain all systems of water.
I find no threaded drain plug on the exterior of the water heater. Every previous TT owned had such a plug.
Any clues as to how to drain water heater tank???
Photo in my photo file (do not know how to add to post)
Appreciation!
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
04-05-2018, 08:33 AM
LEV ZEPPELIN
2004 19' International CCD
Chicago
I see something that may be the plug under the black wire toward the left. The photo isn’t clear on my phone. My plug is inconveniently located close to mechanicals of hwh.
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
04-05-2018, 09:02 AM
Fr Jeff
1989 29' Excella
Saginaw
, Michigan
Plug
That is actually the electric heating element. It might well drain from that spot if I remove the cord plug and the threaded fitting that holds the element inside the tank. May have to do that.
Thanks for the tip.
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
04-05-2018, 10:34 AM
Tampa
The drain would be near the bottom, Duh!
I've never seen a WH without a drain, but I'm no expert.
I'm agreeing with a previous post that it's the drain plug.
See Attwood gas electric WH:
04-05-2018, 11:58 AM
LEV ZEPPELIN
Chicago
Frjeff
I would post make and model of wh and see if anyone else can concur with my assesment, just in case.
On my 03 Bambi ccd, I stopped fighting trying to get my plug (nylon) out to drain wh years ago. I found that opening all low point water valves and opening preasure relief valve on wh drains everything nicely. No problems so far with Chicago winter. All other winterize procedures followed that, except I only use compressed air, no antifreeze.
04-05-2018, 12:20 PM
2000 30' Excella
Toledo
, Ohio
Appreciation!
What is that behind the gas valve looks like the drain plug.
04-05-2018, 10:11 PM
1995 25' Excella
xxxxx
, xxxxxx
I see where it is supposed to be....Right behind the gas line to gas valve connection.
04-06-2018, 05:18 AM
Sag Harbor
, New York
At the lower left, either the black or silver circular shape should be it. Not the bottom heating element with the wires leading to it.
The silver one looks like it may have an old galvanized square-head threaded plug in it? Difficult access for sure!
Do you have the owner’s manual or one for the water heater? If you post the mfg. and model number, we can probably find the correct documents.
Good luck,
Peter
PS — best to use the drain, not just the low point drains elsewhere IMO. Need to get crud sediment out of bottom of tank.
04-06-2018, 05:34 AM
Sag Harbor
, New York
PS this may be your owner’s manual IMO:
https://www.airstream.com/wp-content...ream-TT-OM.pdf
On p. H-69 [PDF p. 240/269] is the water heater info.. On p. 247 is Figure 1 for the pressure adjustment, which looks like your black circular shape on the left. This leaves the silver as the drain IMO.
At the top of p. 253 in the Winterization section, it refers to a pet-cock drain valve, which may be the silver shape? Can you turn that nut head and have water drain out a small hole on the shaft, or remove it? Your unit is so old that the threads may be frozen IMO. A new heater may be in order sadly.
Good luck!
04-06-2018, 06:31 AM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Lower left-hand corner is where your drain plug would’ve been located someone has added an optional hott rod Heating element to give you additional electric heat you have to remove the brass hott rod from the drain hole to drain the water heater. See link below
http://www.campingworld.com/hott-rod...n-kit-6-gallon
04-06-2018, 07:17 AM
Sag Harbor
, New York
Good call, thanks!
04-06-2018, 08:40 AM
Tampa
Originally Posted by OTRA15
My god, that's thorough! I enjoyed surfing through it even though mine doesn't apply. It's almost a service manual.
BTW, my old WH had the nylon plug, and I discovered it's easy to bung up the head while trying to remove it using a crescent wrench, or open end. I eventually bought a socket that could snake in there and remove it.
OBTW, don't stand in line with the opening when removing the plug unless you need a quick bath.
02-02-2019, 01:25 PM
2020 27' International
St Augustine
what size socket was it? 1 inch?
