Old 08-04-2004, 12:05 AM   #1
TroutStream's Avatar
Water Heater Door... Safari Tim?
Tim, inspired by your step by step guide, I managed with great effort to remove the Bowen water heater (had to drag it out using a tow-rope and my truck).
Now I have a big hole in my wall. I just want to remove the door from the Bowen and plug the hole for the time being until the fall when I put an Atwood in there. I have run a water to by-pass the heater for now. But I read that you removed your door and switched the Atwood door for the Bowen.
Any help on how to remove door would be appreciated.
Ken
ID:	8149   Click image for larger version
TroutStream is offline   Reply With Quote
Old 08-04-2004, 01:00 AM   #2
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Smile Don't blame me!
Yikes you got a big hole there!
You opening looks different from mine. It looks taller and narrower.
Anyway, on removing the old cover, all it takes is popping the little metal hinge wires out of their slots and the door comes off.
When I put the door on the new heater, I added a screw across the metal tab to keep the pin from falling out while under way.
Since you will not have a water heater there for some time, you will have to fashion a different way to hold the cover in place.
Let me know if you need some specific pictures or anything else.
-Tim
theVAP - Airstream Podcast
Old 08-04-2004, 09:08 AM   #3
Thanks Tim!
I think the hole looks bigger because of the perspective (I hope that's the case!) I've been told the Atwood will slide right in. If the new one slides in the way the old one slid out, then I'm in trouble as I literally had to drag it out with my truck!
I may break down and buy the Atwood this week but I won't have time to put it in before we go away this weekend (2 weeks). We're going to a provincial campgroud (BC) where we will be using the water pump. The park has hot showers and flush toilets but no hook-ups.
Thanks for the help!
Ken
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Water Heater By-Pass? TroutStream Water Heaters, Filters & Pumps 4 09-01-2004 07:15 PM
Winterization Blues - Water Heater Question BrianRegan Water Heaters, Filters & Pumps 0 06-13-2004 11:36 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
