Old 06-06-2007, 09:17 PM   #1
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Question Water heater does not work on 110.
I tried to use my water heater on 110 a few weks ago and nothing but cold water. It does work on propane. I have checked my 12V DC side. Power to the switches and the switches are passing 12 V.
Where is the 110 element? on the back? I need to check it for continuity.
Michelle TAC MT-0
Sarah, Snowball
Old 06-09-2007, 08:56 PM   #2
Keymar , Maryland
With no suggestions or obvious problems. I dug into trouble shooting.
I checked the circuit board. 12V to the board to command electric heating, 12 V out to the relay.
After a consulation with Airstream of Spokane. I was able to locate the heater element and the relay. the realy was getting 12V and I hear the relay click after a slight delay of command electric heat.
So I started checking the 110 side. The heating element had continuity. Good news! I was getting 110 to the relay but not out of the relay. Ah ha!
I pulled the wire off the relay and check there. 110 present. ok bad wire connection. breaker off. I recrimped the one end and replaced the terminal end with a ring terminal at the heating element on both the hot and neutral.
I turned the breaker back on and tried the electric heat. She worked!
Woooo hooo.
A bill for 1.5 hours of labor will be going to Airstream.
Michelle TAC MT-0
Sarah, Snowball
Old 06-09-2007, 09:03 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Is this a Classic thing?
I don't have 110 on my water heater at all, just propane. Is a dual source water heater a Classic only thing?
Paula
See you soon at Rivette's Summer Solstice.
Old 06-09-2007, 09:04 PM   #4
Keymar , Maryland
Paula,
I believe the Internationals and the Classics have electric. Safari's propane only.
Michelle TAC MT-0
Sarah, Snowball
Old 06-09-2007, 11:40 PM   #5
dpandorf's Avatar
2000 34' Limited
Somewhere in Western , North Carolina
I have to do some trouble shooting on my water heater too. I have the combo 110/propane and my 110 side is not working. Just got the used trailer and may have been my operating error as a newby by leaving the switch on after emptying.
Not sure what element I need yet, if that is the problem. Do like the advantage of using both at the same time to get the over 14 gal/hr recovery rate vice a little over 8 for either electric or propane.
Duane Pandorf
Blog | Google+
Air# 16888 | 2000 34' Limited | 2008 Ford F250
dpandorf is offline   Reply With Quote
Old 06-10-2007, 06:30 AM   #6
lewster's Avatar
Naples, FL , Hood River, OR
Nice job Michelle!!
Keep it up and I'll have to put you to work!!!!
I was going to suggest that you check that relay. I have had more problems with those than the elements themselves! It's the first place I look now.
Old 06-10-2007, 06:54 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Get a spare
Relays seem to be the bane of the mechanic. They are small and relatively inexpensive, why not get a spare one, for when it really does go south on you?
Old 06-10-2007, 09:59 AM   #8
Keymar , Maryland
Terry,
I plan on having a spare. I may have temporaily fixed the problem. I also have somewhere a solid state relay that should be able to handle the current. that will last a lot longer. baring that I will get a spare from AS.
Michelle TAC MT-0
Sarah, Snowball
Old 06-10-2007, 06:44 PM   #9
lewster's Avatar
Originally Posted by thecatsandi
Terry,
Michelle,
A Bosch heavy duty 40 amp relay should do the trick. Available at NAPA for way less than A/S .
Old 06-10-2007, 09:01 PM   #10
Keymar , Maryland
Lew,
still under warrenty and I will get a replacement from AS at no charge.
I will also take a trip to the local NAPA store and have a look at what they have. They have always been helpful.
Michelle TAC MT-0
Sarah, Snowball
Old 06-10-2007, 09:31 PM   #11
lewster's Avatar
Free is always GOOD!
Old 06-10-2007, 09:40 PM   #12
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Terry,
The way Michelle travels I suspect she will be heading south herself later in the year so she might be able to catch up to that errant relay .
Michelle, great work figuring out what the problem was, and thanks for letting the rest of us know how you resolved the problem.
The quality of relays and other little parts and pieces we've come to rely on sure has deteriorated it seems in the past five or so years. Same thing with bearings and seals. It seems like they are made so poorly now and the same with tail light bulbs - there are so many almost brand new vehicles with burned out tail light and brake lights.
Barry
safari57 is offline   Reply With Quote
Old 06-11-2007, 05:32 AM   #13
Well Preserved
1993 21' Sovereign
Barry
While overall quality may have slipped a little (A LOT), there are other reasons now for modern cars and trucks to have non-functioning lights.
New vehicles no longer use the trusty 1157 bulb and the twist lock socket, they use a straight plug in type bulb, like a #3057. The contacts get wet and corrode, or the higher current draw of the bulb melts the plug. I have cleaned off the melted plastic many times, and the bulb has started working again.
Another issue is the wiring harness, Marie's car has had a problem with the left taillight since the day we bought it, I have replaced the bulb, and socket, and wiring harness. It will work for a few months, then go out again. It is currently not working (again) so I will have to go work on it (again).
Old 06-11-2007, 06:35 AM   #14
lewster's Avatar
Terry,
How about a little dielectric grease as a seal after you plug it in. Or just replace the thing with an LED model (new 3 watt 1157s and 3057s are now available and are brighter than the OEM bulbs).
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water Heater & Water Tank mgordon Water Heaters, Filters & Pumps 23 01-15-2003 06:58 PM
Bowen water heater Jerry Sulkin Water Heaters, Filters & Pumps 8 08-23-2002 08:26 AM
Water Heater Replacement, Others roessler Water Heaters, Filters & Pumps 9 06-18-2002 03:53 PM
