Old 06-11-2007, 06:38 AM   #15
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by lewster
Terry,
How about a little dielectric grease as a seal after you plug it in. Or just replace the thing with an LED model (new 3 watt 1157s and 3057s are now available and are brighter than the OEM bulbs).
I have tried dielectric grease, as well as lithium grease, with no joy. Next step would be LED's.
Old 06-11-2007, 07:53 AM   #16
Images: 59
I don't think my Suburban water heater has a relay.
What type of water heater is it?
Old 06-11-2007, 10:18 AM   #17
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Barry,
I went around and replaced all my runing lights with LEDs. My tail light are already LED. I hope they last for quite a long time. Inside I have very few incadescent lights. When I am done there will be only four.
I too am dis-hearted with the quality of some of the components.
Michelle TAC MT-0
Sarah, Snowball
Old 06-11-2007, 10:18 AM   #18
Keymar , Maryland
Water Hear make.
Atwood I believe.
Michelle TAC MT-0
Sarah, Snowball
Old 06-11-2007, 11:15 AM   #19
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Michelle,
We are trying to do the same on th '51 with LED's while retaining as much of the vintage look/feel as I can. Donna picked up a couple of lights at a truck light place that may work for replacments of the marker lights. The ones that were put on the trailer some time in it's 56 years of use are pretty ugly and the installation was, at best, brutal. Eventually we will have all but a couple of lights moved over to LED's and my neighbor is busy adapting all his original lights in his '58 Silver Streak to work with LED's so I may just do the same with mine.
Barry
safari57 is offline   Reply With Quote
Old 06-13-2007, 09:31 AM   #20
Keymar , Maryland
Followup
I called Bodily RV near Boise. They are the closest Airstream dealer. I will be passing by on June 28th. I made an appt and then asked to talk with the parts dept. They parts guy told me he did not have the parts diagram for the -10E and was looking at the -9E. It showed no relay. I told him where it was on the heater and he still could not find it. I cancelled the appt.
I then called AS of Spokane. They have never let me down. Doug pulled up the -10E diagram. It did nto show the relay either. THe box the relay is attached to is part of the tank! You have to get a new tank to get the relay! How stupid is that? I am going to take Lew's suggestion and get and appropriately rated Relay from the Auto parts store.
Michelle TAC MT-0
Sarah, Snowball
Old 06-13-2007, 08:50 PM   #21
safari57's Avatar
1960 24' Tradewind
West Coast , BC
Michelle,
It is a tad scary how some parts folks (and other firm employees) view their role in the whole customer satisfaction/customer retention as either not being important, or they are not trained sufficiently or motivated enough to go the extra mile when a client calls in - whether it's a local or long distance caller. Just being able to go to the correct schematic for your trailer is a huge confidence builder. Trying to figure out why a part is not shown in the parts catalogue yet is a component of what the client has is an important part of their role if they are going to be effective and gain your trust and hard earned dollars. You are fortunate that the relay is available from an alternate source and that you are knowledgeable enough to know that and to acquire it there.
Today I picked up the replacement bearings for the '57 I'd ordered 10 days ago. As I suspected and feared, I only got part of the shipment as the order taker was not listening when I explained what it was I needed, and also was not listening when I asked him to make sure he made a note that I required all of the parts that were indicated as included in the kit and not just what they happened to have on the shelf that day - no backorders - hold it till it is all in stock. The shipper "forgot" to include the gaskets and one of the seals, did not take notice of the hold until kit complete, and when I called to find out what happened did his best to lay the blame on the order taker, however, it was all right there on the shipping papers so there were a few embarrassing moments for the young lad.
Fortunately the machine shop who pressed the old bearings off and new ones on happened to have sitting on a shelf the correct seal and their parts guy knew what was in stock, what fit what, and was concerned that I might not be able to get my TV back on the road in time for our trip next week if we couldn't find the pieces. Then to make my experience with them even better, given it's an odd seal for axles they almost never see any more, they gave it to me. I'll make my own gaskets. But I'm hugely impressed with them and I will make sure my car club buddies are all aware of how customer focused they are. As for the parts supplier, everyone makes mistakes, but I'll be more cautious about ordering from them in the future.
Barry
Old 06-13-2007, 10:00 PM   #22
Darol Ingalls's Avatar
Safari 57, Barry, You're right about the light bulbs - I'm still running the original T-3 high beams in my '64 Star Chief. Don't drive much at night anymore, but they're still working after 43 years. Hope to see you in August at the Demming rally. Darol
Darol Ingalls is offline   Reply With Quote
Old 06-20-2007, 10:56 PM   #23
Keymar , Maryland
Followup followup
I just placed an order for a Solid state relay. 3-32 volts control and 12-275 VAC up to 50AMP load. That is over three times the max load I expect. A small heat sink will be necessary but that will not be a problem. It should be here Monday. Just in time to install it before I head to Boise.
I seriously thought about a automotive relay but could not find out if the insulation is rated for 120VAC. I went the safe route and ordered a special purpose one.
Lew stop by if you apasing through!
Michelle TAC MT-0
Sarah, Snowball
Old 06-21-2007, 06:25 AM   #24
dpandorf's Avatar
2000 34' Limited
Somewhere in Western , North Carolina
Water heater repair
Hi Michelle, I'm trying to figure out where this relay is on my unit and exactly what part I should order to fix mine. I've looked at the outside of my unit and of course can see the propane part of the heater. I can also see where the wires connect. However, where I suppose the relay is located its covered by a black insulated cover material with adhesive. I started to pull the small rectangular insulated cover off but didn't have time to mess with it the other day.
Duane Pandorf
Blog | Google+
Air# 16888 | 2000 34' Limited | 2008 Ford F250
dpandorf is offline   Reply With Quote
Old 06-21-2007, 09:39 AM   #25
Keymar , Maryland
It is on the back. I got to it through the bathroom. There is a panel next to my toilet. I removed it and was staring at the back of the water heater.
Michelle TAC MT-0
Sarah, Snowball
Old 06-21-2007, 09:45 AM   #26
dpandorf's Avatar
2000 34' Limited
Heating element location
Thanks, I'll got look in there next week when I get home from work.
Duane Pandorf
Blog | Google+
Old 07-20-2007, 09:40 PM   #27
Keymar , Maryland
Finally installed.
An installation update. I finally got around to fixing my water heater. I know she is still under warranty but I was having trouble finding the replacement parts. I got all my parts and finally had a day off with time to install the parts.
I removed the old relay. Installed the new solid state relay and heat sink. It is mounted higher in the compartment than I wanted but I was able to get it vertical so convection cooling can occur.
The test works!
The first picture was the old install.
The second is the new one.
ID:	41563   Click image for larger version
Michelle TAC MT-0
Sarah, Snowball
Old 07-21-2007, 05:19 AM   #28
lewster's Avatar
Naples, FL , Hood River, OR
Hey Michelle,
Nice job!
You were probably on the road when I passed thru Boise last month. Had a stop to make at Best RV Supply there. Randy is a great guy and carries super stuff!
Maybe we'll catch up somewhere on the road....................
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water Heater & Water Tank mgordon Water Heaters, Filters & Pumps 23 01-15-2003 06:58 PM
Bowen water heater Jerry Sulkin Water Heaters, Filters & Pumps 8 08-23-2002 08:26 AM
Water Heater Replacement, Others roessler Water Heaters, Filters & Pumps 9 06-18-2002 03:53 PM
