Old 07-11-2010, 07:11 PM   #1
1979 23' Safari
Laurens , South Carolina
Water heater does not shut off (NEED REMEDY)
We recently purchased a '79 Airstream Safari and everything seems to be in good working order, but we lit the water heater and the water is getting hot but the thermostat does not seem to be working. We have turned it up and down and there is no difference. Unfortunately, we have the (ITT) thermostat and not the Unitrol, so the service manual does not give any advice on it and I can not find any on the web. Anyone have any suggestions or a parts diagram for the ITT thermostat. We are taking it on its maiden voyage in two weeks and would love to have this fixed.
Trish
Ttuck118 is offline   Reply With Quote
Old 07-11-2010, 07:14 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
how long did it run for. It takes 15-20 min sometimes to heat the water up.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-11-2010, 07:23 PM   #3
1979 23' Safari
We had it set on the lowest possible temp and the water had gotten hot enough that you could not hold your hand under it and it still had not shut off. I was probably 10 min.
Old 07-12-2010, 03:38 PM   #4
1979 23' Safari
Thanks Jason. You were right, we just were not waiting long enough. It took it about 30 min. to get up to temperature to shut off.
Water heater thermostat does not shut off gas to burner davelance01 Water Heaters, Filters & Pumps 2 06-12-2009 09:55 AM
City water inlet shut-off valve? boondockdad Fresh Water Systems 11 01-13-2009 11:08 AM
Black Water Tank Shut-off Leaking tntom Waste Systems, Tanks & Totes 2 07-03-2008 06:38 PM
Black water shut off valve? '73 Sovereign Al Falcon Waste Systems, Tanks & Totes 10 05-14-2007 04:28 AM
External Water Shut-off on FB units wheel interested 2006 - 2010 Classic (all lengths) 8 09-09-2006 11:12 PM
