Old 06-08-2008, 08:54 PM   #1
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
Water heater crud-fest
I bought one of those yellow plastic wands that attaches to a hose for flushing the water heater tank. Since it was a nice day, I decided to give the Atwood a spring flushing. I opened the drain plug, lifted the pressure release lever and drained out the tank. Nice, clean water flowed.
After the tank was empty, I stuck the wand into the tank through the drain hole and let her rip. I moved it around, trying to get all of the interior surfaces (nice trick when you can't see them).
HOLY CRAP!
The amount of white flakey crud that came out of the tank was amazing! We have pretty high water pressure in our part of town, so maybe that helped pulverize the calcium/lime/whatever crap off the tank walls, but there was a LOT of chunky stuff coming out the drain hole.
So... what are the odds that I still have any tank wall left? Was this really deposits from the water, or does this sound like my tank needs its diaper changed? Nothing looks like it's leaking inside the rig...
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 06-08-2008, 09:03 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Florida water has very high "crud" content. The white flakes are little chunks of lime and calcium from the hard water here. I have to clean the strainer out of both sinks in our trailer every other month here. Our one year old water heater probably has as much crud in it as yours.
The water heater was used for about 2 years before it made its trek to North Carolina, so it should still have life left in it, provided it didn't crack from freezing, and you should already know if that happened.
Old 06-08-2008, 09:15 PM   #3
bobfowler's Avatar
1972 Argosy 20
Images: 14
Thanks Terry, I figured it had some life left to it as it still heats the water real well.
While camping, I've been taking the aerators off the faucets every couple of days to clean out the crud. That was my clue that maybe we needed to flush out the water heater tank and the lines. With water in the lines and aerators off, I blew about 40 pounds of air pressure in via the city water connection to purge the pipes. We did this a couple of times today, and by the 4th time, no more chunky crap was showing up in the sinks.
The last air purge was to force the water out of the water heater (via the drain hole). It's pretty cool how a little air pressure can REALLY make that crap come flying out!
Bob Fowler
TAC - NJ-007
Old 06-08-2008, 09:29 PM   #4
A 7th year newby
IndyAnne's Avatar
1968 24' Tradewind
Indianapolis , Indiana
Images: 8
Send a message via Yahoo to IndyAnne
pictures! We need pictures!
I would love to see photos of that crud. It's sensational, and, it makes me feel so much better when someone else has crud.
Right now, I'm a little queasy from finding a little mouse skeleton in a spider web.
Seriously, I'd like to see what you found, so when I do the same, I'll know how much to panic, or not.
Anne
HOLY CRAP!
Anne
Indianapolis, IN
TAC IN-7
1968 Airstream Trade Wind
2005 Chevy K1500 crew, reg. bed, 4WD, gas
IndyAnne is offline   Reply With Quote
Old 06-08-2008, 09:33 PM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I have one of those cleaning tools. Mine was called a Tank Saver. It originally had a copper tube which is now plastic. First time I used this on my old trailer which was 10 years ago, I couldn't believe how much crud was in my tank. I normally used this every fall when I winterize. Doing it on an annual cycle minimizes the amount of stuff that comes out. It will extend the life of your tank.
Tank Saver Flushing Tool - Camping World
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-12-2008, 06:41 AM   #6
A 7th year newby
IndyAnne's Avatar
1968 24' Tradewind
Images: 8
Tech specs
Sounds like backwashing the pool filter, sort of. Wait for clear water. I think I'll get me one.
Anne
Tech Specs
Weight: Less than 1 lb.
Mfg Part #: TS-550
Tech Notes:
How to Flush Your Water Tank with Tank Saver
* Turn off water supply to RV.
* Open faucet to bleed off pressure.
* Open outside water heater door and remove drain plug.
* Connect Tank Saver to hose and insert into drain opening, pointing down.
* Open valve on Tank Saver and work wand all around to stir up and flush out sediment.
* Flush for about 2 minutes or until water coming out is clear.
* Turn off valve, remove wand and re-insert drain plug.
Jack
Anne
Indianapolis, IN
TAC IN-7
Old 06-12-2008, 07:54 AM   #7
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
I just replaced my who-knows-how-many-year-old-water heater in 1975 Safari. Mine had whitish-looking gooey particulate matter in the bottom which came out with the residual water when I tilted it over to let it drain. From the design of these tanks, they don't drain out all the residual water and they can collect some nasty stuff. Thanks for posting info about the "Tank Saver"--I think I'll get one to keep my new water heater clean!
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
How to remove old caulk, glue and crud? Zstream Leaks - Weatherstrips, Gaskets, Caulks & Sealants 28 05-26-2008 02:46 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
Cleaning crud from fresh water tank Tin Diesel Fresh Water Systems 6 01-23-2006 12:42 PM
