Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 04-18-2004, 07:07 PM   #1
Profile:
Water Heater "Clicked" Off
We made our first Airstream outing of the year this weekend. While sitting in the front couch, minding our own business, there was a loud "click" which seemed to come from the bathroom (center bath). Upon investigation I discovered the water heater was no longer operational.
Investigating the possibility that the switch itself had decided to make a trial run as a fuse, I pulled it out (the switch is in the bathroom). It tested fine, but I left it out for the night. The next day I put it back in to see if I had voltage back at the heater, and when I flipped on the switch, Cape, we have ignition!
Now, somebody please tell me what happened and why.
Mark
Old 04-18-2004, 08:34 PM   #2
Profile:  LOST , Hawaii
Sounds like the Mississippi group is trying to keep their Missouri president's trailer in tip top shape; one of those stealth repairs.
John
74Argosy24MH is offline   Reply With Quote
Old 04-18-2004, 08:47 PM   #3
WayWard Wind's Avatar
Profile:  2004 25' Safari
Could be that the water heater burner was calling for ignition & failed, for whatever reason. It then timed the control out till it was reset by turning the electrial switch off & then on again. I think the manual calls for a 30 sec reset time. Or then again it could be ?????
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 04-18-2004, 09:11 PM   #4
Profile:
It was dead for, oh, 10 min. or so. Maybe longer - I gave up and went to bed.
Mark
Old 04-19-2004, 05:10 AM   #5
Profile:  1993 29' Excella
Jonesboro , Louisiana
It could be as simple as the thermostat cycling off. Did you have plenty of hot water at the time? If it happens again, run some hot water and see what happens.
James Schmidt
29 ft Excello 1000
97 Expedition/Hensley Hitch/
McKesh mirrors
James Schmidt is offline   Reply With Quote
Old 04-19-2004, 06:13 AM   #6
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Sometimes when mine shuts off it makes a rather loud click. The gas valve is what I think is making the noise.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 04-19-2004, 08:12 AM   #7
Profile:
No, it didn't just shut off. It went dead.
The only thing that makes any sense to me is that the circuit breaker (thermal) snapped off, and later reset. It suddenly occurs to me that if that is, in fact, the case, perhaps what I heard was the gas valve suddenly snapping shut.
Mark
Old 04-19-2004, 11:00 AM   #8
Mark--I'm not sure just how your water heater wiring is configured, but on our unit (2002 Bambi ), if the therm-o-disc ( hi temp ) control opens it will not auto reset. In fact our manual says a new therm-o-disc is required. Just a thought.
Best,
Bogfrog & Mr. Turbo
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 06:16 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 11:29 AM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 06:37 PM
Water Heater Advice! John Sims Water Heaters, Filters & Pumps 1 06-16-2003 09:43 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 08:26 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
