Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 02-09-2018, 09:55 AM   #1
1970 27' Overlander
Texas City , Texas
Water Heater Choices????
hi everyone....!!
so i'm now at choosing a water heater......thinking of going with the Exothermal Atwood 10 gal.(#94026) but can't find any reviews on any of it's sources....does anyone have this unit and how do you like it??? Pros..Cons ?? Talked with VTS....but not a review.......
It seems to offer alot of benefits....price is midway between other Atwoods and Tankless.....but i'll be living in my
AS and i want a product i can use both LPG and Electric.....so i'd like to see if i can get other opinions/feedback on this product before buying! Thank you, as always !!
Teri
terirdh is offline   Reply With Quote
Old 02-09-2018, 10:27 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I have the Atwood tankless, and after a lot of fiddling I can live with it. Not exactly a glowing review right? Yep. It wastes a lot of water getting to the shower, and if the water pressure goes down you may mever get hot water. In some campgrounds filling the tank and using the pump is the only way to get hot. Low propane pressure cuts off the heater too. Outside resetting the shower covered in soap.. grrr
Dual fuel in either 6 or 10 gallon size conventiomal Atwoods is good. Easiest is to replace with the same size.
corian color preferences and vinyl floor choices? 2airishuman General Interior Topics 9 02-28-2005 06:57 PM
mattress choices ? vajeep Upholstery, Blinds, Walls & Interior Finishes 6 02-23-2005 05:22 PM
Header choices ALANSD Mechanics Corner - Engines, Transmission & More... 5 01-31-2005 02:07 PM
choices choices technautica Our Community 7 12-23-2003 05:46 PM
need to install a water heater...choices? pixie Water Heaters, Filters & Pumps 6 03-20-2003 06:24 PM
