Old 11-06-2011, 09:44 AM   #1
CowtwnSilver's Avatar
2004 19' Bambi
Fort Worth , Texas
Water Heater Bypass Valves '04 19ft bambi
Manual days in lavatory cabinet. Can't find the valves. Suggestions?
CowtwnSilver is offline   Reply With Quote
Old 11-06-2011, 10:15 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Don't understand your post, but look under the bed for the water heater bypass valves. Should be 2 circular holes drilled in the plywood base of the bed to access them.
Old 11-06-2011, 10:27 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
I've got a buddy with a corner bed in a 23' International. Access to his HWH isolation valves is under the mattress, just below the curbside window. You'll find them near the outer rim of the bed on either side of the HW heater.
5 meter Langford Nahanni
Old 11-06-2011, 10:37 AM   #4
2004 19' Bambi
Fort Worth , Texas
Got it. Thanks everyone!
Old 08-26-2012, 09:57 PM   #5
2015 30' FB FC Bunk
Phoenix , Arizona
Smile 2004 19' Bambi Water Heater Bypass Valves
Hi there....relatively new owner to a GREAT 2004 Bambi Safari....need some help and this may be a no brainer but need to be sure.
PROBLEM: Water heater fires up, lasts about 30-45 seconds.....shuts off.....light at water heater switch operates normally....but, we get no hot water from the fresh water tank. I dont believe it is a lighting or thermostat problem.
When we were at home connected to city water, we did get water from the bath and kitchen sinks. We purchased this from a couple who had winterized it.
I suspect it is because the Hot Water Heater BY-PASS valve is on so no water is getting to the Hot Water Heater.
QUESTION:
Where is the By-Pass valve? If it is under the bed, I see a WHITE and RED line with valves and they are BOTH in the CLOSED position. (running at 90 degrees like a plus...not in line with the pipe).
Should I open BOTH of these valves to allow flow?
I am perplexed because when I opened them, some water did come out from under the water heater carriage but not alot so I thought they should be closed but now I am not sure how they should be in order for HOT WATER to flow from the tank?
HELP??!?! A cold shower was NOT fun.....
THANKS for your insight.
TGadaire is offline   Reply With Quote
Old 08-26-2012, 10:54 PM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I just lifted the mattress in our 19' Bambi (06) to check the positions of the valves...
There are two holes in the bed floor panel... the rear hole is to access the low point water system drains...those should both be closed position, 90 degrees to the line (in the X position)...open those and you drain all the water in the system through the floor onto the ground just behind the water heater. (You can see where those lines come through the floor if you look under the trailer.)
There are three valves you can access through the forward hole...the valve in the white line and the valve in the red line should both be open (parallel to the line). The valve that connects the two lines (red line on one side of the valve and white line on the other side of the valve should be closed in the 90 degree position (in the X position).
My guess is that you are correct...your water heater was not getting any water supply. Be sure water heater has water in it before you light it. You can test to see if you have water in it by turning on the hot water using the pump or city water connection. If water comes out, then the water heater is in line with the system.
I don't envy you having to take a cold shower. Boo!
TB & Greg and Abbey Schnauzer
#3954
Old 08-27-2012, 05:41 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
A very quick method of checking if the tank has water in it is to lift the relief valve lever, and see if water comes gushing out.
Replacing Water Heater in Argosy 24ft '75 HELP!! eyelashsoup Water Heaters, Filters & Pumps 10 08-23-2011 07:56 PM
Atwood water heater fast cycling Skater Water Heaters, Filters & Pumps 4 07-22-2011 07:02 PM
Water heater won't lite aswbe Water Heaters, Filters & Pumps 6 06-06-2011 09:18 PM
Water Heater Calcium Deposits -- What to do? Wilmington Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
