Old 10-15-2015, 01:40 PM   #1
2016 25' Flying Cloud
Sedona , Arizona
Water heater bypass
Haven't even looked yet, but maybe someone can save me time and much cursing. 2015 rear twin FC 25'...where is the hotwater bypass located in this baby? Seems like every model year is different. Winterizing right around the corner. Appreciate the tip. regards/steve
sandrade is offline   Reply With Quote
Old 10-15-2015, 07:16 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Welcome sandrade. Congratulations on your 2015 Airstream. There are a lot of people who own the Flying Cloud 25 in it's many configurations.
I'm surprised your owner's manual doesn't point you to the bypass circuit and valves. But none the less, I'm sure someone with a similar model will reveal the location for you.
Yep, winterizing is coming up. I need to get mine done also.
David
Old 10-16-2015, 05:27 PM   #3
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
My 13 has only one valve to turn,,,
Old 10-16-2015, 05:43 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have a 2012 FC rear queen bed and I suspect the setup is the same. It's one valve located under the foot of your streetside twin bed, there is an interior access door and it is inboard toward the center of the trailer, in front of the water heater.
I've only used it once, since then we have been snowbirding south before freeze up. With the exception of tonight, we are enroute visiting my son's family farm in Minnesota, 25 degrees forecast tonight. I drained the low point water lines and tanks, and will use the furnace to get us through.
Doug and Cheryl
Old 10-16-2015, 06:25 PM   #5
dkottum's Avatar
Just looked again, the bypass valve has a yellow T-shaped handle on a water line going into the water heater, hard to miss. The handle is turned parallel to the water line for normal operation, perpendicular to the water line for bypass.
Doug and Cheryl
Old 10-17-2015, 04:25 PM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Interesting to read how far Airstream plumbing has progressed compared to my oldies but goodies. My system needs three valves to bypass the water heater. All of the valves are hard to get to.
I wonder what the plumbing circuit or valve design looks like with just one easy to access valve to bypass the water heater?
I'll have to "google it!"
David
Name:	1404 Plumbing Water Heater Bypass Valves.jpg
Old 10-17-2015, 05:04 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Simple; they put a check valve on the hot water side of the water heater and a three way valve in the cold water line. When in bypass mode the check valve prevents the anti freeze from going back into the WH. A$ is not the only coach to use this method.
TG Twinkie is online now   Reply With Quote
Old 10-18-2015, 05:59 AM   #8
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks TG Twinkie. Now I understand how it is done.
David
water heater bypass Chuck Water Heaters, Filters & Pumps 9 11-09-2004 07:40 AM
Location of water heater bypass buckeroo2 Water Heaters, Filters & Pumps 2 04-02-2004 06:43 AM
Water heater bypass installation Craig Water Heaters, Filters & Pumps 4 04-05-2003 04:13 PM
water heater bypass tomb 1984 - 1989 Sovereign 1 11-22-2002 01:04 PM
Water heater bypass niftypkg Water Heaters, Filters & Pumps 0 05-15-2002 05:38 PM
