Old 01-10-2009, 07:46 PM   #1
2007 25' Safari FB SE
Kennesaw , Georgia
Question Water heater by-pass valve position?
Ok, rookie question; the by-pass valves on the hot water heater lines on an '07 Safari 25 FB SE...
Is the valve "closed" when the valve handle is "in-line" or parallel with the line? Or is that the "open" position?
The manual is un-clear; it shows the valve handles in a 45-degree position, neither parallel nor perpendicular to the line.
Thanx, Lance
TennisMan is offline   Reply With Quote
Old 01-10-2009, 09:45 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
The valves are closed when they are crosswise. The visual position directly corresponds to what happens to flow.
This pic is the valve position when winterized so one doesn't waste gallons and gallons of antifreeze. The HW heater still has to be drained by the exterior plug. The valves should be in the opposite state during regular water use.
5 meter Langford Nahanni
Water heater bypass valve Robfike General Motorhome Topics 6 05-11-2014 06:21 PM
Water Heater gas valve littlefeller Water Heaters, Filters & Pumps 5 11-14-2007 07:04 AM
Water valve position question chuman70 Fresh Water Systems 5 06-03-2007 06:23 PM
Water Heater By-Pass? TroutStream Water Heaters, Filters & Pumps 4 09-01-2004 07:15 PM
Water Heater By-Pass Kit Dwight Water Heaters, Filters & Pumps 16 09-24-2002 07:40 PM
