12-07-2010, 06:22 PM
1966 24' Tradewind
Oak View
Water heater blues
I have a new question. Recently I was trying out all the appliances to be sure they worked OK. Checked the hot water heater and the base of the flame is blue, but it seems to me that there is quite a bit of lazy yellow flame after it. I read the instructions and it said that spiders and such can cause obstructions in the burner baffle (I think that is what it was called) I carefully unscrewed the part indicated and it said to slide it up the tube so you could insert a flexible wire brush to clean inside. It will only slide a little ways before it hits an elbow in the tube and not enough to gain access with a hair much less a wire brush. I am nervous about using it with that much yellow flame. What do you think?
Photo one shows sleeve with screw removed
Photo two with sleeve slid to right as far as it goes
12-07-2010, 07:44 PM
Corona
Check the LPG pressure. Should be 12 inches of water column pressure.
Clean the oriface.
Clean the burner tube.
By the way, Airstream's do not use "how water heaters".
But they do use "cold water heaters".
12-07-2010, 07:51 PM
1977 27' Overlander
1963 19' Globetrotter
Naples
You should be able to pull out the entire burner and give the whole thing a good cleaning.
Dave
12-07-2010, 08:37 PM
Master of Universe
2008 25' Safari FB SE
Grand Junction
Carol, the thing to remember is that is has to come apart. I expect you have to remove the gas valve (I think that's the thing on the left partially in the photo) and the pipe and burner will probably come with it. You'll have to take apart the propane supply line somewhere, maybe to the left of the gas valve. Make sure the gas is off. When you put the pipe back together, use teflon pipe tape to get a better seal—use the yellow tape, it's for gas lines (white is for water pipes). You may have to use 2 pipe wrenches to get it apart.
The pipe is screwed onto the gas valve and could be detached there, but I can't see how it could turn since it goes into the burner chamber so far as I can tell. But there seems to be a support for the pipe under it at the mouth of the chamber. If that was unscrewed, would it release the pipe somehow and then it could be unscrewed at the gas valve? I doubt this is the solution, however.
The thing that slides ("baffle") controls how much air is mixed with the fuel and you can move it until to get the best flame and tighten the screw. I believe the igniter is the white thing with the wire attached on the upper right and that needs to be cleaned gently also. It its mounting plate unscrews, you can take the igniter off and see inside better and clean more. The igniter will come out of the mounting plate, but I am unsure how, so be careful. After putting things back together, check all the joints in the gas pipe with soapy water to make sure you have no leaks. When working with gas it's a good idea to be paranoid.
I haven't worked on our Airstream water heater, but have installed gas appliances and pipe and fixed a few appliances, and they are all pretty much the same in principle, but my guesses may not be correct.
If you are worried about explosions, or like to smoke a cigar while working on this or use a candle to see better, get someone else to do it.
Gene
12-07-2010, 08:42 PM
1966 24' Tradewind
Oak View
Am I supposed to unscrew that big copper bolt to the left of the red wire? The sleeve will not move to the right far enough for me to have access to the burner assembly to clean it. All the instructions said were to remove the small screw from the baffle and slide it to the right. Not possible...
12-07-2010, 08:50 PM
1966 24' Tradewind
Oak View
Gene, I didn't see your note till I posted. I will give it a try and will refrain from puffing on any cigars while I do it. Perhaps moving the baffle to allow less air to flow in will change my flame, sounds like it would make sense and it would be the easiest thing to try first.
12-07-2010, 08:53 PM
1970 27' Overlander
Espanola
, Full Timer
Andy- it's not a 'HOW water heater' thats supposed to be a cold water heater...it's a 'HOT water heater' thats supposed to be a cold water heater. ....
12-07-2010, 09:04 PM
Naples
There is a 1/4" hex head screw that holds the burner tube onto the combustion chamber at the bottom. The flange is held there by 2 (IIRC) of the same screws. By removing the flange from the combustion chamber mount, you can then remove the burner tube from the gas valve without touching the valve to clean it out.
Be VERY CAREFUL not to put anything thru the LP orifice except compressed air or maybe carb cleaner, as it is precisely drilled and easily damaged.
And even though Andy had a typo in his post, there is no such device as a 'hot water heater'. The device that you have pictured is simply a 'water heater', as it DOES NOT HEAT HOT WATER. Rather, it creates hot water from the incoming water, be it warm (like in the south in the summer) or cold (like incoming water now).
And always remember....NEVER LEAVE YOUR BATTERIES ON CONCRETE!!!!!
lewster
12-07-2010, 09:24 PM
Corona
Yeah, I know, sometimes a key or two gets misplace on my wifes computer at home.
Yes, it's supposed to be "hot" not how.
Sorry folks, but I still stick to my rights as a senior.
And besides, I don't always remember what I forgot. Hmmmm.
12-07-2010, 09:29 PM
1966 24' Tradewind
Oak View
OK, I will go over there and try these things VERY carefully....
Thank you,
Carol
12-07-2010, 09:50 PM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
That's really great. I must remember this one. Are you related to Yogi Berra? Or is that something he is supposed to have said?
Very funny indeed.
12-07-2010, 09:58 PM
1966 24' Tradewind
Oak View
Maybe could someone take a peek at their hot water heater when it is on and tell me what their flame looks like? I was assuming that it should look like the burners on my stove. Mostly blue with a yellow tip. Mine has blue with 3-4 inches of yellow.
12-07-2010, 10:09 PM
1970 27' Overlander
Espanola
, Full Timer
Ours runs blue when lit. and I myself...if I remember right (which might be wrong) - the flame is yellow or can be peppered with yellowish flame when it is said to be burning too rich, a term for out of adjustment. Due to air mixing not being right..........right?
I also wanted to go sideways here and mention that we moved away from the old house location because the city power line coming from the alley came loose from the house and was swinging two feet from the ground and fifteen feet away from the TT. The city came out and condemned the house to be torn down. Every night I was going to sleep with one eye open that whole time we were there, watching for yellow flames flickering on the wall.
I did not want to start a thread about that because I did not want to see a whole line of 'I told you so's' ....
12-08-2010, 11:12 AM
1966 24' Tradewind
Oak View
So, do I want more air or less air going into the tube? I can slide the sleeve with the slits in it slightly to accomplish this by giving it lots of air or a little air...
12-08-2010, 11:30 AM
Corona
First, make sure the LPG pressure is ok.
Then make sure the orifice is clean. You can do that by removing it, and soaking it in "limeaway" for a day or two.
Then fire up the water heater. Adjust the slider so that the burner makes a little roaring noise. At that point, the vast majority of the flame will be blue. Go for the maximum amount of air, then back off the adjustment. Too much air will make the flame sputter.
A yellow flame indicates a lack of oxygen.
12-08-2010, 12:04 PM
1966 24' Tradewind
Oak View
Thanks Andy, I am not sure how to check the LPG pressure. I assumed it was OK since my stove burners and catalytic heaters run fine.
01-18-2011, 04:36 PM
1966 24' Tradewind
Oak View
Hooray! It's fixed!
All this trouble because of a little eight legged hitchhiker that had hunkered and built a furry little den down in the baffle. Now I know what that blue flame roaring sound is supposed to sound like...
Thank you all for your help with my water heater!
Carol
01-18-2011, 04:46 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
yay, the bearstream has hot water!
Ricky
07-03-2011, 03:38 PM
1972 23' Safari
raleigh
, North Carolina
The device that you have pictured is simply a 'water heater', as it DOES NOT HEAT HOT WATER. " someone pointed out
...and what about ATM machines....since the "M" stands for machines?
Do you want a water heater in your Airstream, or a HOT water heater? Which sounds better? A water heater sounds like something for your water bed.
too much communication is better than too little, so "Hot Water Heaters" live on as do ATM machines.
To stay on topic, I'm working with one of my 69 tradewind Airstream's hot water heater now, heck, I'd settle for a water heater.
Like others, I'm very afraid of GAS, as I work on it and as I sleep with it.
07-03-2011, 04:38 PM
Master of Universe
Grand Junction
VIN number is like ATM machine.
Carol, haven't seen a post for a while. I hope you still have hot water and are doping well.
Gene
