07-03-2011, 05:29 PM
#21
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by CrawfordGene
VIN number is like ATM machine.
Carol, haven't seen a post for a while. I hope you still have hot water and are doping well.
Gene
I was doping well yesterday....today not so much.
07-03-2011, 05:55 PM
#22
Master of Universe
2008 25' Safari FB SE
Grand Junction
She used to be nurse—you never know. Lots of dispensaries in Cal. and Colo.
Gene
07-03-2011, 06:02 PM
#23
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Gene
As you, Carol rites gud, miss her posts.
Since I been back I notice 2air, Safari57, and Stwinkie MIA also.
07-03-2011, 06:09 PM
#24
Master of Universe
Grand Junction
Carol do rite gud and I miss her too.
Silvertwinkie absented himself after he was acting as a mod on the WBCCI website and getting a lot of flack about it.
Safari 57: last post June 26, 2011.
2air disappeared March 5 and has removed all information about himself.
Gene
07-03-2011, 09:14 PM
#25
2004 28' International CCD
Birmingham
, Alabama
I PM'd 2Air a couple of weeks back following up on a repair question from a few months back. If you were wondering ... He's alive and well but says there's nothing new to post.
07-09-2011, 07:32 AM
#26
Islander
2005 28' International CCD
Deer Harbor
, ORCAS ISLAND WA
and so
out of the blue....my water heater does not ignite....nothing....turn on the switch...no red light.......
read the instructions.....no clues.....worked fine yesterday.....not today,,
are there fuses....where....thoughts
thanks
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
07-09-2011, 07:57 AM
#27
Master of Universe
Grand Junction
Every once in a while a gas appliance does not work. Some idiot (me) removed the propane tanks and when he replaced them, forgot to turn the propane back on. The good thing about being an idiot is that the solution is easy—turn the gas back on. There are times to hope you are an idiot.
Gene
07-09-2011, 08:05 AM
#28
Islander
Deer Harbor
, ORCAS ISLAND WA
idiot's delight
alas, the propane is on....double, tripple checked that first....light at switch will not respond......no juice??? fuse????
Kingfisher24
WBCCI 2541
4CU
07-09-2011, 09:39 AM
#29
Master of Universe
Grand Junction
Light should come on regardless of whether the flame lights or not—there's a different pattern for working and not working.
After the idiot's delight fix doesn't work, the fuse is the next simple thing.
Do you have a wiring diagram with the stuff you got when you bought the trailer? If so, that can help with troubleshooting.
If you don't hear the flame and the light doesn't come on, it could be a fuse or a loose wire on that part of the circuit that operates the light and the igniter. If you don't have spare fuses, borrow one you know is good for the water heater fuse. I believe the 12 v. circuits are identified on the inside of the converter cover under the bed.
Then it is loose wires. And cleaning the igniter—though I'd think the light would work regardless of the condition of the igniter.
I think there's a circuit board to control the electrical part. That can be shorted out by bugs, dirt, dust, or cracked, or otherwise blown.
Since our trailer is the same age and trim line as yours, and I have seen people reporting problems with their water heaters at about 3 or 4 years, I guess I should be looking ours over and clean parts and check them.
Gene
07-11-2011, 11:35 AM
#30
Islander
Deer Harbor
, ORCAS ISLAND WA
lesson learnt
so apparently some something partially clogged gas tube and causes a flame flare up which scorched the thermal cuttoff wire and .......
in that event there is no juice to fire the electronic ignition and therefore the red light cannot come on and the heater can not make hot water
and a 14$ part and an expensive service call and ..........
Kingfisher24
WBCCI 2541
4CU
