Old 12-08-2010, 11:30 AM   #15
Originally Posted by cclarkego View Post
So, do I want more air or less air going into the tube? I can slide the sleeve with the slits in it slightly to accomplish this by giving it lots of air or a little air...
First, make sure the LPG pressure is ok.
Then make sure the orifice is clean. You can do that by removing it, and soaking it in "limeaway" for a day or two.
Then fire up the water heater. Adjust the slider so that the burner makes a little roaring noise. At that point, the vast majority of the flame will be blue. Go for the maximum amount of air, then back off the adjustment. Too much air will make the flame sputter.
A yellow flame indicates a lack of oxygen.
Old 12-08-2010, 12:04 PM   #16
cclarkego's Avatar
1966 24' Tradewind
Oak View , California
Images: 8
Thanks Andy, I am not sure how to check the LPG pressure. I assumed it was OK since my stove burners and catalytic heaters run fine.
cclarkego is offline   Reply With Quote
Old 01-18-2011, 04:36 PM   #17
cclarkego's Avatar
1966 24' Tradewind
Images: 8
Hooray! It's fixed!
All this trouble because of a little eight legged hitchhiker that had hunkered and built a furry little den down in the baffle. Now I know what that blue flame roaring sound is supposed to sound like...
Thank you all for your help with my water heater!
Carol
Old 01-18-2011, 04:46 PM   #18
richinny's Avatar
2011 34' Classic
yay, the bearstream has hot water!
Ricky
Old 07-03-2011, 03:38 PM   #19
1972 23' Safari
raleigh , North Carolina
The device that you have pictured is simply a 'water heater', as it DOES NOT HEAT HOT WATER. " someone pointed out
...and what about ATM machines....since the "M" stands for machines?
Do you want a water heater in your Airstream, or a HOT water heater? Which sounds better? A water heater sounds like something for your water bed.
too much communication is better than too little, so "Hot Water Heaters" live on as do ATM machines.
To stay on topic, I'm working with one of my 69 tradewind Airstream's hot water heater now, heck, I'd settle for a water heater.
Like others, I'm very afraid of GAS, as I work on it and as I sleep with it.
djofraleigh is offline   Reply With Quote
Old 07-03-2011, 04:38 PM   #20
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
VIN number is like ATM machine.
Carol, haven't seen a post for a while. I hope you still have hot water and are doping well.
Gene
Old 07-03-2011, 05:29 PM   #21
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Gene
I was doping well yesterday....today not so much.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 07-03-2011, 05:55 PM   #22
Master of Universe
Gene's Avatar
She used to be nurse—you never know. Lots of dispensaries in Cal. and Colo.
Gene
Old 07-03-2011, 06:02 PM   #23
Gene
As you, Carol rites gud, miss her posts.
Since I been back I notice 2air, Safari57, and Stwinkie MIA also.
PFC
"Tahawus"
RLC
John Prine
Old 07-03-2011, 06:09 PM   #24
Master of Universe
Gene's Avatar
Carol do rite gud and I miss her too.
Silvertwinkie absented himself after he was acting as a mod on the WBCCI website and getting a lot of flack about it.
Safari 57: last post June 26, 2011.
2air disappeared March 5 and has removed all information about himself.
Gene
Old 07-03-2011, 09:14 PM   #25
UAPachyderm's Avatar
2004 28' International CCD
Birmingham , Alabama
I PM'd 2Air a couple of weeks back following up on a repair question from a few months back. If you were wondering ... He's alive and well but says there's nothing new to post.
UAPachyderm is offline   Reply With Quote
Old 07-09-2011, 07:32 AM   #26
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
and so
out of the blue....my water heater does not ignite....nothing....turn on the switch...no red light.......
read the instructions.....no clues.....worked fine yesterday.....not today,,
are there fuses....where....thoughts
thanks
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 07-09-2011, 07:57 AM   #27
Master of Universe
Gene's Avatar
Every once in a while a gas appliance does not work. Some idiot (me) removed the propane tanks and when he replaced them, forgot to turn the propane back on. The good thing about being an idiot is that the solution is easy—turn the gas back on. There are times to hope you are an idiot.
Gene
Old 07-09-2011, 08:05 AM   #28
Islander
idiot's delight
alas, the propane is on....double, tripple checked that first....light at switch will not respond......no juice??? fuse????
Kingfisher24
WBCCI 2541
4CU
Atwood water heater fast cycling Skater Water Heaters, Filters & Pumps 4 07-22-2011 07:02 PM
Water heater won't lite aswbe Water Heaters, Filters & Pumps 6 06-06-2011 09:18 PM
Sealing around atwood water heater Hueytownalss Water Heaters, Filters & Pumps 1 06-02-2011 10:07 AM
Water Heater Calcium Deposits -- What to do? Wilmington Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
