Old 10-10-2015, 02:05 PM   #1
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Water heater blowing fuses
First a chain of events.
I drained my water heater to put a new drain plug in. Filled it up and went in to turn it on. It is a gas only Atwood 6 gallon. Flip the power switch and heard a pop. Checked the inside fuse board and a 20 amp fuse was blown. Swapped it out and it blew again when I turned the switch on. I have checked all the connections on the heater and the 2 amp fuse on the control board. Everything looks ok. Any suggestions?
MICHAEL
Old 10-10-2015, 02:20 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
No idea. But when you drained the heater, could you have inadvertently disconnected some of the wires in the hot water heater box outside the trailer? Maybe bumped in to them and crossed one or two of them?
SteveSueMac is online now   Reply With Quote
Old 10-10-2015, 02:25 PM   #3
AWCHIEF's Avatar
Images: 33
That was the first thing I checked. All are secure.
MICHAEL
Old 10-10-2015, 03:39 PM   #4
AWCHIEF's Avatar
Images: 33
Problem solved. On another site it was suggested that I pull all the wires and use a hair dryer on the connections. Did that and low and behold I have hot water.
MICHAEL
Fuses, what fuses? safariuser Electrical - Systems, Generators, Batteries & Solar 8 04-06-2015 05:52 AM
Fuses blowing, battery sparking - 69 Overlander 27' mcstubbs Batteries, Univolts, Converters & Inverters 5 07-23-2009 04:27 AM
Blowing 30amp Fuses takeachance Generators & Solar Power 2 06-14-2007 12:43 PM
Running Lights blowing fuses neil.ervin Electrical - Systems, Generators, Batteries & Solar 11 04-30-2006 07:37 PM
charging/blowing fuses on the Bambi jonoflewis Electrical - Systems, Generators, Batteries & Solar 7 12-19-2005 06:04 AM
