Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 01-14-2003, 04:49 PM   #15
Swingking
Swingking's Avatar
Profile:
Unhappy
I have rented a truck...
Longhorn Car-Truck Rentals
(512) 452-1773 4812 N I H 35
Austin, TX
$45 a day plus free milage up to 100 miles.
Not bad... right?
Swingking is offline   Reply With Quote
Old 01-14-2003, 04:55 PM   #16
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
That's great
I look forward to meeting you and all of the other Austin and Central Texas folks that, up to next week, are just names on my monitor.
Did you locate the map to the event on one of the other threads? If not, check this post:
http://www.airforums.com/forum...1419#post21419
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 01-14-2003, 06:39 PM   #17
hex
hex's Avatar
Profile:
Lightbulb Gettin there is half + the fun if it works!
Hey Swing that truck does have a reciever type hitch does it not?
Otherwise the truck may get to the camp a little later than the trailer!
Obviously you have not pulled this trailer yet ?
Have you thought about the braking situation?
Also I am not sure about the hitch-ball size, are you?
Good luck and congrats on your buy.
But don't overlook the safety (of you and others)stuff in a mad rush to get out to the park to meet Me!
hex is offline   Reply With Quote
Old 01-14-2003, 07:18 PM   #18
John
Profile:
You're going....
Hex,
Are you going to be there?
Did you get an A/S?
Are you in the Austin area?
John
John is offline   Reply With Quote
Old 01-15-2003, 12:44 PM   #19
Swingking
Swingking's Avatar
Profile:
thanks for the reply
I will check with the truck rental place on the hitch.
- I followed my trailer as it was being towed from houston to austin.
- He told me that he felt the elec brakes were out. but he said it towed great.
-It has brand new tires
I have 7 days of Airstream experience so any and all information is a God send.
thanks!!
Mark
Old 01-15-2003, 01:35 PM   #20
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Water Heater & Water Tank
Greetings Mark!
You might want to check with the firm from whom you plan to rent the truck to be sure that their rental contract does not prohibit towing a trailer. When I rented a pickup to remove refuse from my property after a storm, the rental agreement stipulated that no trailer should be towed with the vehicle (even though it had a class III receiver hitch) - - and if one were to be towed any AND all resulting damages would be the responsibility of the individual signing the contract. Towing a trailer with such contract language could potentially create liability for just about any kind of repair that the lessor might envision a cosequence of towing.
Kevin
Kevin D. Allen
AIR #827
Old 01-15-2003, 05:18 PM   #21
Swingking
Swingking's Avatar
Profile:
I called Longhorn truck rental and...
- it is a receiver hitch
- towing my baby is allowed
now. do I need a....
3/4 ton or a 1 ton pickup to tow my 27' Land Yacht?
note: the trailer is empty for the most part.
thanks!
Mark
Old 01-15-2003, 06:26 PM   #22
overlander64
Anna , Illinois
Images: 106
Greetings Mark!
RE: Tow Vehicle Question
Either truck that you mention should work assuming that it was equipped with the intention of such use. The trailer tow ratings for most 3/4 ton trucks vary from 5,500 pounds and 12,000 pounds depending upon how they were optioned while 1 ton trucks typically range from 8,000 to 15,000 pound tow ratings depending upon how they were optioned.
For your situation, the 3/4 ton would probably provide a slightly gentler ride but the 1 ton truck may have more effective brakes. I mention this because you mentioned in your earlier post that there is some question as to whether the trailer brakes are fully functional.
There is a second issue that you will likely need to be prepared to deal with. It is quite possible that your Airstream may be wired to the unique method used by Airstream (see) that is not compatible with tow vehicles wired to today's industry-standard. My Argosy Minuet was wired to this standard and the backup lights were the only thing that functioned on it when it was first connected to my Suburban (they were wired to the 12-volt charge line terminal); all other lights operated in manners other than intended. The current standard isn't terribly different (see) , but it does require shifting several wires. It is also possible that you may need to change from a 7-pin round connector to a 7-blade connector to be compatible with a modern tow vehicle.
Good luck with your excursion.
Kevin
Kevin D. Allen
AIR #827
Old 01-15-2003, 06:41 PM   #23
Swingking
Swingking's Avatar
Profile:
Everyone....
I certianly appreciate all of the help!!
The truck that towed the trailer from austin to houston was a Dodge Ram Desiel. probably 1999 - 2000 model.
The brake lights and turn signals worked great (thank god)!!
I am HOPING that it is wierd correctly. whaddya think?
boy there is a lot to think about when going out on your first outing with "Wally".
Mark
Old 01-15-2003, 07:58 PM   #24
primatreat
primatreat's Avatar
Profile:
water heater replacement
I am considering replacement of my water heater in my "75 center bath soverign. The manual says " remove in and out water lines from the rear". They are reached from the bathroom.. Anyone know just what has to be removed?. Looks like I must pull the toilet to get the plastic insert(that holds the vent switch and opening). Can I still get parts for the Bowen? I broke the flame spreader..
My RV is really "down by the Delaware
river" Frenchtown, NJ
primatreat is offline   Reply With Quote
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 11:29 AM
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 09:16 PM
fresh water tank filling system nickcrowhurst Fresh Water Systems 5 03-16-2004 01:37 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 08:26 AM
Leak in hot water heater tank Rog0525 Water Heaters, Filters & Pumps 8 06-10-2002 03:10 PM
