Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 06-16-2003, 08:22 PM   #1
John Sims
Profile:
Post Water Heater Advice!
I determined I had a water heater leak after noticing soft spots in the bathroom floor of my 1971 International. I had this trailer for two years and have never been able to get the water heater to work.
After pulling the water heater I determined it was a fitting that was leaking. The water heater tank was fine. The furnace and the case around the tank was rusty.
I would like some advice on repairing the unit or replacing it. I'm thinking at this point to start new since the current unit is over thirty years old.
I'm going to patch a large portion of the floor since it's water damaged. Any advice on that would be appreciated.
Thanks, JSims
John Sims is offline   Reply With Quote
Old 06-16-2003, 08:43 PM   #2
JPAIRSTREAM
JPAIRSTREAM's Avatar
Profile:  1972 31' Sovereign
, Ohio
Images: 47
replace with a 10 gallon atwood. perfect fit little modifications.
JP
JPAIRSTREAM is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Water Heater T&P 99 Bambi Leaking, need advice JimBrownUT Water Heaters, Filters & Pumps 3 01-14-2004 02:46 AM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 05:37 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
