Old 06-20-2016, 08:22 AM   #1
FreedomRings's Avatar
1984 31' Excella
Naples , Florida
Water Heater advice
Any advice as to how to get this to ignite since I don't have a Pilot valve and looks as if no electrical capacity. Gas only?
ID:	264835   Click image for larger version
FreedomRings is offline   Reply With Quote
Old 06-20-2016, 08:32 AM   #2
It works simply.
The ignitor switch is in the bathroom. It is electric and works off your battery.
When you turn the switch, the heater opens the gas valve and sparks the ignitor. If it lights you hear a whoom as the burner ignites the flame heats the hot water.
If there is no gas or some malfunction, the ignitor sparks a couple of times and then the unit shuts off as a safety factor.
About all you can do as an amateur is to make sure you have propane gas getting to the heater and enough battery to spark the ignitor. If you have a manual you can perhaps adjust the flame so that it stays on and burns cleanly without an excessive roar. If there are more problems, they should be dealt with by a skilled rv tech.
handn is offline   Reply With Quote
Old 06-20-2016, 08:46 AM   #3
nilesrob's Avatar
Marietta , Georgia
Images: 12
Not sure in yours, but in our gas water heater there is an inline fuse. Sometimes you can see a burn in the fuse, which would cause your heater not to ignite. But I had a situation where the fuse looked good, and yet it was not. So if your heater has a fuse and you can replace it, that is a simple, cheap and easy thing to try without putting yourself at risk. Bugs sometimes build nests in the vent pipe, so another thing to check. Otherwise, I'd follow the previous post and have someone who knows what they are doing work on it.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 06-20-2016, 09:54 AM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The connections on the circuit board (upper left) may be corroded. Disconnect each wire and clean the connections.
Old 06-26-2016, 10:11 PM   #5
1976 29' Ambassador
Atlanta , Georgia
Originally Posted by handn View Post
It works simply.
Ha! So that's what that little round nub switch was. I spent most of the day gutting my new '76 Ambassador. By the time I got to the bathroom, I was in full hack and slash mode so I just cut that wire without giving it a lot of thought. I plan on getting an auto ignition water heater so I assume that switch is no longer needed...
Now to get that &$#@$ water heater out of there...
Chae is offline   Reply With Quote
Old 06-27-2016, 07:24 AM   #6
1984 31' Excella
Naples , Florida
Furnace and water heater advice needed triplenet Furnaces, Heaters, Fireplaces & Air Conditioning 11 02-02-2010 07:22 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water Heater T&P 99 Bambi Leaking, need advice JimBrownUT Water Heaters, Filters & Pumps 3 01-14-2004 02:46 AM
Water Heater Advice! John Sims Water Heaters, Filters & Pumps 1 06-16-2003 08:43 PM
