Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Prev Previous Post   Next Post Next
Old 08-10-2009, 10:55 AM   #1
chasrahm's Avatar
Profile:  1970 31' Sovereign
Dallas , Texas
Water Heater Adjustment? Gas Pressure too low?
1970 International - water heating for the first time in years! Cleaned tubes and verified the thermocoupler works. I believe I properly bled the air out of the water tank (just ran the hot water at the kitchen sink until all air burped out)?
Water heater fired up and ran for about 7 minutes and then turned itself off. I turned on the hot water at the kitchen sink and in a few moments had very warm water but not too hot that I wanted to remove my hand.
It didn't last too long, maybe hot water flowed warm for 2 - 3 gallons and turned back cool. I walked back around to the heater and it had not turned itself back on. The pilot light was still burning. I turned the thermostat hotter on the heater and it still did not fire back up.
I checked the propane bottle and it was very light, i thought empty. But when I removed the bottle, it felt like it still had a small amount.
Do the water heater controls have a sensor that prevents operation if gas pressure is too low?
Is there an adjustment to the temperature sensor other than the adjustment knob?
How many gallons does this heater hold?
Many thanks,
Charles Rahm,
Dallas Texas
chasrahm is offline   Reply With Quote
Water heater pressure relief valve woliners Water Heaters, Filters & Pumps 6 07-10-2008 08:12 AM
Low hot water pressure??? FBC72 Water Heaters, Filters & Pumps 2 07-29-2007 11:49 PM
low water pressure dikku Fresh Water Systems 7 07-26-2007 10:50 AM
water heater pressure relief valve wayne.yl Water Heaters, Filters & Pumps 12 04-21-2007 06:54 AM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 08:12 AM
