Old 06-10-2012, 03:35 PM   #1
L911's Avatar
1971 18' Caravel
Cookeville , Tennessee
Images: 12
Water Heater
I would like to replace or convert the existing hot water heater to electric, should i buy a conversion kit or just replace it with a new gas/electric unit?
L911 is offline   Reply With Quote
Old 06-10-2012, 05:39 PM   #2
cameront120's Avatar
1972 25' Tradewind
If you have the original Bowen water heater from 1973, you're better off swapping it out with a new Atwood that runs on both propane and electric. It's an easy swap. The new one will fit in the space of the old one.
North Vancouver, BC
Old 06-10-2012, 06:10 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I don't believe that the original 1973 heater can be converted to electric. If you decide to upgrade you will have to pull wiring and add a breaker to your panel. If your 1973 is a rear bath like mine that won't be too hard as the water heater is adjacent to the breaker box.
Aaron
WBCCI #XXXX AIR #2495
Old 08-15-2012, 02:42 PM   #4
wbcci3371's Avatar
1993 34' Limited
Scituate , Massachusetts
Water Heaters in '73? I had a '73 Excella 500. I just added a 120v outlet under the sink from the one over the sink. Then I plugged in the new Hot Rod after switching it with a 20amp single pole switch nearby the cabinet door.
The hot water heater on 120v ran a little cooler than the LP, but it was just fine and took about 1hour to recover. When traveling, it is cheaper to run on the CGs power than run your own LP. It is a good deal and pretty easy to install too.
Rich wbcci3371@gmail.com
Rich
wbcci3371 is offline   Reply With Quote
Old 08-15-2012, 04:08 PM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I put a new Atwood gas/electric in my 88 and I did not wire it into the trailer. I use a seperate cord and plug it into the 20 amp outlet that is in most campgrounds now. I did not want to do the additonal wiring in the trailer and also did not want to add the WH draw to the 30 amp service. If I want to I can plug it into the existing outside outlet on the trailer but have not opted to do that.
Frankly I like heating water with propane a lot better. I run it about 20 min at night and 20 min in the morning and we have hot water all day.
My trailer came with one of the add on electric heaters. It was a poor unit and poorly installed. I ripped it out right away.
Old 08-15-2012, 05:19 PM   #6
Splitrock's Avatar
Sioux Falls , South Dakota
I installed a gas/electric 6 gallon Atwood water heater. It was an easy job and it works good and fast on 120 volt eclectic. I'm still in the construction stage and I haven't tested it on gas yet. I'm happy I bought this unit. If I needed a new one, I'd buy this one again.
Old 08-15-2012, 05:54 PM   #7
toastie's Avatar
1955 22' Safari
Great Lake State , .
I went completely 120V, read my thread number #655, #656 then #808 through #820. http://www.airforums.com/forums/f36/...-38289-47.html
toastie
toastie is offline   Reply With Quote
