Old 08-08-2011, 11:50 AM   #1
1978 Argosy 30
prospect , Maine
Water heater?
I think I have an original propane hot water heater in my '78 argosy. My question is...why does my pilot light keep going out after it is done heating the water to the temp I have it set for. In the owners manual, it says you can adjust the pilot but mine came with no adjustment skrew. Would appreciate any input. Im a brand new owner of the airstream family and my family just came back from our maiden voyage and love it!
thegirouxs is offline   Reply With Quote
Old 08-08-2011, 12:37 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Check for soot on the thermocouple - clean it carefully. It's the silver probe thing that sits in the pilot flame when lit. Also check for blockage in the gas opening - if partially blocked then not enough heat to keep the thermocouple hot enough to keep the flame going. Also check the placement of the thermocouple in the flame - it should be fully engulef to keep the gas open to the pilot flame.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-08-2011, 12:49 PM   #3
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Could be
Is it sufficiently blocked from the wind? Is the wind blowing it out? If original, could be that the orifice is partially blocked...
Argosy 30 - cool.. not many of the big larger than 28 foot Agronskis around.
Curious - why are you heating hot water - ... ref: your "Hot Water Heater" comment..
I know.. just joshing you.. as I used to say the exact phrase...
you might want to check the gas line... if original, it is guaranteed to have his nasty black goo in the line.. perhaps enough to restrict gas flow enough that your pilot light goes out...
Let's see some photos of that Agronski 30
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 08-08-2011, 07:08 PM   #4
1978 Argosy 30
prospect , Maine
Well thank you very much for the replys. I'm gonna try all the different cleaning options and adjusting the thermocouple at the flame. And for the pics, hopefully they will be here shortly. Thanks again.
Old 02-12-2012, 03:17 PM   #5
FL Crackers's Avatar
2012 27' FB International
Ft Myers , Florida
ROBANDZOE,
I'm having similar trouble with my WH in an original '77. I have changed out the thermocouple assembly but don't know how to go about cleaning the gas line. Is there a chemical that I could introduce from the tank end? Any suggestions would be appreciated.
It was fine for the first tank last weekend, but the pilot went out and wouldn't stay lit. Changed over to the second tank, but no-go. Changed out the thermocouple (both parts) and still can't keep the pilot lit.
Mike & Laurel
Ft. Myers, FL
2012 27FB Int'l Serenity
2016 RAM 2500
FL Crackers is offline   Reply With Quote
Atwood water heater fast cycling Skater Water Heaters, Filters & Pumps 4 07-22-2011 07:02 PM
Water heater won't lite aswbe Water Heaters, Filters & Pumps 6 06-06-2011 09:18 PM
Sealing around atwood water heater Hueytownalss Water Heaters, Filters & Pumps 1 06-02-2011 10:07 AM
Water Heater Calcium Deposits -- What to do? Wilmington Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
