Old 10-23-2010, 11:26 AM   #1
cottonwood , Alabama
Water Heater
79 Sovereign center bath need original door. i found plenty of white but no alum.
tomdmax is offline   Reply With Quote
Old 10-23-2010, 12:12 PM   #2
Ottawa , ON
paint the white one...
Old 10-23-2010, 12:14 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
This is my white door painted.
http://img.photobucket.com/albums/v1...g?t=1278182564
Old 10-23-2010, 12:57 PM   #4
x
XXXX , XXXX
Do you have the original heater or a replacement one. The doors are different.
wasagachris is offline   Reply With Quote
Old 10-23-2010, 01:09 PM   #5
1971 29' Ambassador
South Weber , Utah
Factory white door didn't fit...belt trim overlapped bottom of water heater about an inch. I removed the door from the new water heater and installed the old "stainless" door with the space for the trim onto the new heater. Took a bit of fabrication to get the spring clips installed to hold the old door closed on the new heater but works great.
fisherjdou is offline   Reply With Quote
Old 10-23-2010, 02:55 PM   #6
Splitrock's Avatar
My heater is a new Atwood gas/electric 6 gallon. The door came to me steel and powder-coated white. Now it's steel powder-coated white, primed gray, and painted metallic aluminum.
Water wood rot under toilet and water heater! Mrcrowley General Interior Topics 4 12-01-2008 03:34 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 08:17 AM
Water heater & fresh water capacity ESCAPE POD Water Heaters, Filters & Pumps 5 11-14-2007 05:14 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 01:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 05:24 PM
