Old 04-13-2015, 05:28 PM   #1
Water heater
Water from my water heater is kind of milky and frothy with a funny smell. Do I need to replace the unit? Or is there some kind of easy fix?
hatband01 is offline   Reply With Quote
Old 04-13-2015, 05:52 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Anyone here will tell you I'm no expert at this :-) but it sounds to me like you probably have some RV antifreeze in the water heater. If you're connected to city water, don't turn on the water heater (or let it cool down if you have) and just run your water from the hot side of the faucet til it runs clear. You may have to dump your gray tank if you have to run it a long time. Good luck!
Old 04-13-2015, 05:54 PM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Ditto on that..... that's what I was thinkin'.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Propane Heater or Instant water heater valontjej Plumbing - Systems & Fixtures 1 04-09-2012 08:56 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
