I'm still in the throes of acquisition of my 1971 Overlander, but expect to take possession next weekend.
At the moment, the stainless steel canister that holds the water filter (under galley sink) is disassembled.
Can someone point me to a good spot to buy the gasket, clamp, and water filter cartridge for this apparatus?
I don't have the old cartridge, so I've got no info to go on.
Thanks.
One other thing: Seller acidentally backed the A/S into a large stump, so there is a large dent in back bumper that interferes with the operation of the hinged access door back there.
Can I remove the bumper, pound it out, and re-install? How will that look? Anyone think I should replace it?
My units PO didn't winterize last year so the Everpure canister froze and got deformed to the point that it is unusable. So I bought a Culligan RV type filter a Lowes and installed it. It just filters sediment and has a carbon filter for taste. We bring bottled water for drinking and cooking anyway. I don't think I would drink the water out of the fresh tank, even if my trailer was brand spanking new.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce! Air # 283
Regarding the bumper, yes you can take it off and pound it out. The PO of my trailer caught the edge of the bumper and bent it out and downward. I took it off (4 bolts) and pounded it out with a rubber mallet. I then took an abrasive wheel and file and smoothed the whole surface. i was going to polish it, but it came out looking so nice as a brushed finish that I left it. It matched the unpolished (but still clearcoated) finish of my trailer much better.
On my first long trip, in Poteau, OK, an old lady driving a big old car backed out of a parking space and into my bumper. I was about 50 yards away and heard her hit and saw the trailer bounce.
Like Tripp, I removed the bumper and pounded it out using a block of oak and a mallet. On mine, there were 4 Phillips-head screws holding the bumper on. I had to use the largest screwdriver I own with a crescent wrench on the shaft for leverage to get the screws out. I used emery paper and then rubbing compound to smooth the surface.
I do have an area about the size of my hand that doesn't quite match the rest of the bumper, but it doesn't look bad. I see it because I know it is there. No one else has remarked on it.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
The filter cartridges are out there but not sure if the Camping World 19269 is the correct cartridge for a 1971. Take it out and look for part/model number on the canister and go from there. I think the Everpure 150 was used also.
Here is what you want to avoid getting into your drinking cup! I split this SHURflo a couple of weeks ago because it stopped working. Duh, I wonder why. It is not out of my Airstream but one that I used to transfer water while dry camping. It too will get it’s own strainer/filter.
Randy
John,
Yes it is. I have a 94 also and the water out of the small sink faucet is the only faucet that uses the filter. Not sure about the 71 in question though. The filtered water taste the same as bottled water to me.
Randy
