Old 04-22-2015, 07:21 PM   #21
Living Riveted since 2013
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
Here's what we use to regulate and filter water that comes into Rocinante for our use. Apparently, it's a relatively simple solution. We drink the water, shower in it, flush with it, etc., as we can't be bothered with carrying even more tanks (bottles / jugs) of fresh water in addition to the one that came with our trailer.
Tienda Rocinante - Water Filtration
Old 05-06-2016, 02:13 PM   #22
2015 23' Flying Cloud
2023 Interstate 19
Scottsdale , Arizona
If we use a double filter (sediment/carbon) is there any drawback to filtering out everything including the CL?
cactusjk is offline   Reply With Quote
Old 05-06-2016, 02:31 PM   #23
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
We use a .5 micron carbon filter and water softener.
It costs $12 for the filter and $.33 for salt.
We regenerate maybe twice a month and replace the filter every couple of months.
All water passes through this prior th enter to entering the system. Soft water is nice with 3 of my women having long hair and no hard water spots is a pleasure too!Click image for larger version
Name:	ImageUploadedByAirstream Forums1462566672.838503.jpg
Old 05-06-2016, 02:48 PM   #24
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Yes, there is, and you make an excellent point! You really don't want to fill your fresh water tank with non-chlorinated water and then let it sit. That's a recipe to produce a fascinating science fair project, but not necessarily a project you'd want to drink.
I have a carbon filter, but I only use it hooked directly to a pressure system; I fill my tank at home with chlorinated water.
Old 05-06-2016, 03:03 PM   #25
2023 Interstate 19
So maybe I will just use this double filter setup if connected directly into the city water connection. I guess it is okay to fill the tank with regular water at home.
Old 05-16-2016, 01:19 PM   #26
2023 Interstate 19
I am starting to rethink the double filter and am considering going with just an inline ext filter for simplicity.
Old 05-19-2016, 04:50 AM   #27
2023 Interstate 19
Any recommendations on choosing between an inline or canister filter system?
Old 05-19-2016, 06:01 AM   #28
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I always fill my tank using a filter. I also use the filter when connected to water at a campsite.
Next, you most likely have an filter on the cold water line at your galley sink. Look in the cabinet under the sink.
With no hookups, I like to save the water for showering etc, so then a fill a Brita pitcher from the campground spigot for drinking and cooking.
2019 Ford Expedition Platinum
Old 05-19-2016, 06:31 AM   #29
2023 Interstate 19
Single or double filter?
Old 05-19-2016, 06:57 AM   #30
Wayne&Sam's Avatar
Images: 21
I just use one like the cameo inline.
Old 05-19-2016, 07:38 AM   #31
2023 Interstate 19
Thanks. Clearly an easier way to go unless I am missing something?
Old 05-25-2016, 01:19 AM   #32
chaseav's Avatar
2015 25' FB International
I took the advice and bought a Camco inline. It seems to work great but no discernible difference. I'm not tasting water without it though so maybe it's working really well. When they say that it "lasts one season" though, mine did not. I used it for six months and when I tried to use it the next time, water wouldn't flow through it and had to replace. No clue why...? Maybe a "season" is literally just 3 months.
chaseav is offline   Reply With Quote
Old 05-25-2016, 06:12 AM   #33
2023 Interstate 19
On the inlines assume once they are done the flow pretty much stops or is it a gradual decline?
Old 05-25-2016, 07:11 PM   #34
chaseav's Avatar
Mine was a slight slow down but then completely off. I did not cap off the ends of it though while not in use so maybe that's where I went wrong.
Water filtration system Devoman Our Community 8 08-04-2019 09:45 AM
Culligan reverse osmosis water filtration system terryV Fresh Water Systems 9 03-10-2015 11:35 PM
Water Filtration System for Drinking Water kentuvman Fresh Water Systems 6 02-11-2013 08:34 PM
Boondocking gray water disposal and filtration Boondocker Boondocking 18 02-25-2010 09:20 PM
Reverse Osmosis water filtration ncbambi Water Heaters, Filters & Pumps 8 01-26-2010 09:37 AM
