Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 06-05-2008, 07:31 AM   #1
Profile:  2007 23' International CCD
Stratford , Ontario
No Hot Water
As a "newbie" owner of a 2007 Airstream 23' international, I've run into my first hitch. While camping this weekend we couldnt get any hot water. The fresh Water was full, Gas was getting to the stove and furnace. When I hit the water heater switch, you could see and hear the initial roar but after 10-20 seconds would shut off.
The water heater booklet included with my purchase package doesnt seem to address this problem.
One concern I have is whether the tank is actually getting water or if a sensor/electronic circuit is cutting off the firing.
Any Ideas?
PauperPete is offline   Reply With Quote
Old 06-05-2008, 07:41 AM   #2
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
If you have a water heater by-pass installed, have you made sure that it's not still in the 'winterized' position?
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 06-08-2008, 06:38 PM   #3
Stratford , Ontario
Thanks for the advice
I checked under the mattress which is the access for the waterheater in my model. The middle valve was perpendicular and the other two parallel which according to the instructions would be correct. Any other ideas?
Old 06-08-2008, 06:50 PM   #4
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road , Fulltiming
Images: 52
Two suggestions. First, you may have a bad or misaligned senor that keeps the flame lit. If it doesn't see the heat from the flame, it will assume the flame has gone out, and will shut down the gas to prevent a possible explosion.
Second, your trailer should still be under warranty. If so, just make an appointment with the dealer to get it taken care of.
You repair things with tools. You fix things with a hammer.
AIR#2611
Old 06-08-2008, 07:14 PM   #5
AirsDream's Avatar
Profile:  1999 23' Safari
Toledo , Ohio
Just one quick idea: not to be insulting, but did you run the water pump with the "hot" faucet open at sink or shower, so as to actually fill the tank with water? (And is the tank drain pug in place?) It could be that your heater tank is empty and a "hot" safety is shutting it down. You should get air for a while as the tank fills (takes a while with those little pumps) ... then sputters, then a steady stream that'll tell you the tank is full ...
AirsDream is offline   Reply With Quote
Old 06-08-2008, 07:23 PM   #6
AirsDream's Avatar
Toledo , Ohio
I just got another and better idea. I've got a 23 footer, AND WITH A WORKING WATER HEATER! Tell you what ... maybe we could just swap ... Well, though, now that I think of it, moving all the "stuff" I've got in there out and back into a new coach would probably kill me. Sorry, guess it was a bad idea all along.
Good luck getting it running. Hot water IS after all, one of the reasons we don't tent camp any more, right?!
Old 06-08-2008, 07:29 PM   #7
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Pete,
Just curious, how many times did you try the ignition switch? I just dewinterized and noticed that there seemed to be numerous air bubbles in the line. It took 3 times to hit the switch before she took off.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 06-08-2008, 07:35 PM   #8
THE FRANTIC BANANA
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 26
hard start
Half dozen times for us last April.
Fires right up now with all the air out, stove and oven can be a little
stubborn also..
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 06-08-2008, 07:54 PM   #9
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 36
Back to the water heater issue...
When you open a hot water tap in the trailer does anything come out?
You can test to see if you have water in the water heater by opening the relief valve for a second or two. Water should come flooding out.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 06-08-2008, 08:54 PM   #10
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Good one Richard!
Just to summarize what you should look for.
1. open the release valve on the water heater (with your water pump on or connected to city water) and be certain that the tank is filled.
2. run your furnace and stove and be certain that you have sufficient LP in the tanks
3. try the water heater several times as there will probably be an air bubble (or several) in the supply line. Your DSI water heater will try to ignite 3 times and then lock out. You then have to turn off the unit and turn it back on again for anothet 3 tries. It may take a while.
4. the igniter that generates the spark at the burner might be out of position and not seeing enough flame, resulting in the board shutting down the gas valve and turning out the flame.
5. If none of the above works, you might need the LP supply tube and burner cleaned out, or you might have a defective igniter board!
Hope this helps!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 06-08-2008, 09:18 PM   #11
Steve & Susan's Avatar
Profile:  2005 28' International CCD
Willoughby , Ohio
Look closely at your manual. Mine has the exact same diagram for the "winterized" and "summerized" hot water bypass settings. Airstream is supposed to fix the manual, but they may not have.
I'll not be able to get to my AS until next weekend, if you haven't figured it out by then, I'll take a picture and post it of the "summerized" positions and you just reverse them for the winter.
I agree about running the hot water faucet inside your AS. Additionally, you can test the pressure relief valve to see if the tank is full. Just lift the little handle on it A LITTLE BIT to see if water squirts out. If it does, the tank is full. If not, I suspect the bypass is set wrong. Don't open the relief valve too much or you'll take a shower.
Finally, if your dealer is close by, call him and explain the situation. This is one of the reasons I ALWAYS recommend that new buyers video tape the walk-through by the dealer (with close-ups) for future use.
Best of luck - let us know what happens.
Steve & Susan
2005 28' CCD, 2002 Silverado-C1500, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 06-08-2008, 09:21 PM   #12
2008 Safari 27 FB SE
FordTruck's Avatar
Profile:  2008 27' Safari FB SE
Lynchburg , Virginia
We had a 'no hot water' situation when we first took out our new AS. Turned out to be a faulty connection to the heater.
With the door open, it is the last connector to the right, about mid-way up.
Try jiggling it and then lighting the heater again. It might work until you can get it to a service center.
FordTruck
2005 F-150 5.4L Supercab 4X4 (Betsy 3)
2008 Safari 27FB SE (Arvin as in RV'ing)
2006 Harley Davidson Electra Glide Classic
FordTruck is offline   Reply With Quote
Old 06-09-2008, 07:11 PM   #13
Stratford , Ontario
Red face
Thanks for all your advice. I've got my work cut out for me. I'll post the status as soon as I have a chance to work on it. I hope the solution isn't too embarrassing.
Pete
Pingbacks are On
No hot water! Tin Lizzy Water Heaters, Filters & Pumps 2 06-01-2008 09:46 PM
hot water water on demand with a with a normal water heater 62overlander Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Hot Water jfowler218 Water Heaters, Filters & Pumps 1 09-09-2006 09:10 PM
water leak- hot water tank vent glacierrunne Water Heaters, Filters & Pumps 2 05-29-2006 07:14 PM
Hot Water to Hot Raptorrider2001 Water Heaters, Filters & Pumps 3 08-20-2003 06:58 PM
SEO by vBSEO 3.1.0
