Old 03-25-2019, 07:05 PM   #1
2003 Bambi 19’
ski0boy's Avatar
2017 25' Flying Cloud
Crested Butte , Colorado
Water Filter System Under Sink
I have a 2017 Flying Cloud 25 FB and would like some recommendations on under the counter water filtration systems.
Michael
#simply.marsee
ski0boy is offline   Reply With Quote
Old 03-25-2019, 08:06 PM   #2
2016 26' Flying Cloud
Southlake , Texas
I have a Seagull IV and it is supposed to be the best. A little pricy, but what is clean water worth?
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Southlake, TX
WBCCI
Bgibbs is offline   Reply With Quote
Old 03-25-2019, 08:38 PM   #3
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
If you want good water it will be expensive to get it under the sink, because of the lack of space. If you put the filters outside the trailer, you can get good water for much less money.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
Caffeinated is offline   Reply With Quote
Old 03-25-2019, 08:58 PM   #4
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
I also use the Seagull IV. It easily mounts under the lavatory countertop.
Purifies water instantly
Removes: bacteria, cysts, giardia, crypto, viruses, particles, tank taste, odors, specific organic chemicals
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 03-25-2019, 09:02 PM   #5
waninae39's Avatar
2017 22' Sport
NCR , Ontario
we use a triple filer just for drinking water
and a whole house main filet. its is HIGH flow style for all water entering
Name:	high flow water filter with pr regulator.jpg
ID:	336574   Click image for larger version
Name:	drinking water triple filter.jpg
waninae39 is offline   Reply With Quote
Old 03-26-2019, 06:44 AM   #6
2003 Bambi 19’
ski0boy's Avatar
Did you add a new separate faucet or connect it to the kitchen sink?
Old 03-26-2019, 07:47 AM   #7
Seagull IV - Under Counter Install
The kit comes with a separate faucet and I just tee'd off the cold water line under the lavatory counter. I put a shut-off valve in the line to the Seagull IV to make winterization easy (just remove the filter.)
Name:	Seagull IV Install 1.jpg
Name:	Seagull IV Install 2.jpg
Name:	Seagull IV Install 3.jpg
It is small enough that it could be installed under the galley counter, but we felt that it was more convenient in the lavatory for brushing teeth etc. It is handy to fill the kettle there for making coffee and tea too.
Name:	Seagull IV Install 4.jpg
Ray B.
Old 03-27-2019, 06:04 AM   #8
2014 27' Flying Cloud
Stowe , Vermont
The under the galley sink filter was a pain to take off every winter, and put in the bypass pipe, and return the filter in spring. Now I just keep the bypass pipe in year round, and hook up a filter at the city water source out side the AS. Now all my water is filtered.
VT Wanderer is offline   Reply With Quote
Old 03-27-2019, 06:07 PM   #9
waninae39's Avatar
2017 22' Sport
NCR , Ontario
my triple filter is behind the uwave
it goes to a separate tap
its is VERY easy to dismantle.
each of the three cartridges come off with a simple push of a button
here is the water supply connect with a shut off valve
Name:	drinking water filter connect and shut off.jpg
Old 03-27-2019, 07:24 PM   #10
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
My filter sits ON the sink!
https://www.berkeyfilters.com/berkey...hoCUsgQAvD_BwE
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
***Support Airstream Forum***
turk123 is online now   Reply With Quote
Old 04-01-2019, 07:15 AM   #11
2003 Bambi 19’
ski0boy's Avatar
Attachment 336589
Attachment 336590
Attachment 336591
Attachment 336592
Can this filter system be connected to the main faucet cold water vs. installing a separate drinking water faucet?
Old 04-01-2019, 07:24 AM   #12
For a typical RS-1SG cartridge the average life is 1,000 gallons and you would run through a filter fairly quickly running all of your sink water through it. You would need some adapters to put in line with the regular cold water line.
Is there a reason that you wouldn't want the dedicated faucet? You can place it anywhere that you want on the counter top.
Ray B.
Old 04-01-2019, 09:58 AM   #13
2007 27' Classic FB
Ridgefield , Washington
We had the Delta PUR in our 2007 Classic. Really liked it till it died. Unfortunately Delta doesn't make that model anymore. Installed an inline filter which works fine but it is a real pain in the neck to replace.
John
Woosch is offline   Reply With Quote
Old 04-03-2019, 08:53 PM   #14
my3sonsdad's Avatar
1975 Argosy 26
1979 30' Argosy
Vienna , VIRGINIA
Just ordered one of these...filter the intake line on the interior.
1975 Argosy 26
1979 Argosy 30
2015 Jeep GC Summit EcoDiesel w/Hensley
my3sonsdad is offline   Reply With Quote
Under sink water filter Jfed Water Heaters, Filters & Pumps 11 09-17-2013 11:27 AM
Delta Under Sink Water Filter evanskl Water Heaters, Filters & Pumps 0 05-22-2009 11:07 AM
under sink water filter advise Safari64 Water Heaters, Filters & Pumps 3 04-08-2009 07:28 AM
Under sink drinking water filter wacnstac Water Heaters, Filters & Pumps 7 04-05-2006 03:01 AM
Need a Water filter under sink w9det Water Heaters, Filters & Pumps 7 06-29-2005 06:15 AM
