Old 05-06-2010, 08:22 PM   #1
1973 31' Sovereign
Haverhill , Massachusetts
water filter help
I'm replacing the small water filter with a big household one, but I need to know which direction the water goes.
Would the water come through the pump first into the filter, or through the filter first toward the pump?
Any help would be appreciated.
The Veths
theveths is offline   Reply With Quote
Old 05-07-2010, 01:14 PM   #2
1973 31' Sovereign
Nobody knows?
Old 05-07-2010, 01:39 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Occasionally I'm a nobody, but
No, I know.
Tom
Old 05-07-2010, 01:39 PM   #4
TomW's Avatar
1967 26' Overlander
Just kidding. The filter should come before the pump so that the filter can protect the pump from particulates.
Tom
Old 05-07-2010, 04:08 PM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
It is not clear whether you are replacing the small filter at the pump (answer above) or the filter under the kitchen sink. If it is that one the flow is from the pump toward the faucet.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 05-07-2010, 06:15 PM   #6
1973 31' Sovereign
Well, now I'm not sure, I'll have to go figure that out...
It's the little blue plastic one that's about 12 inches from the water pump, it's just got a round aluminum? screen in it and the clear plastic dome cracked.
So there's two filters under the sink?
I'll go have a look around.
Old 05-07-2010, 06:40 PM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
That sounds like a filter for the pump. usually just a screen to keep grit out.
There is probably a canister filter under the sink also. These usually had a charcoal filter in them to eliminate bad tastes. If there that one will be bigger
13 Ram 2500 TD
1969 Overlander Int'l water question - filter on outside water hook up? edmund015 Water Heaters, Filters & Pumps 3 08-20-2009 10:30 PM
water filter dsmith 2002 - 2005 International 9 12-07-2008 09:08 AM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
Water filter Rob30044 Water Heaters, Filters & Pumps 2 07-10-2005 10:24 AM
Water Filter MrTimbo 1974 - 1979 Sovereign 10 08-30-2004 04:18 PM
