Old 03-10-2003, 04:27 PM   #1
Joel Graham's Avatar
Question water filter bypass...?
Plumbing issue with my '71 Sovereign. I want to bypass the old and damaged Everpure water filter. If I were to connect the two copper pipes (inlet & outlet) does anyone know if this will present a water pressure increase that could do more damage? Any help would be appreciated.
Thanks, j. Graham
Joel Graham is offline   Reply With Quote
Old 03-10-2003, 04:41 PM   #2
No problem, we done that in our 71 Trade Wind.
The filter only restricts the flow of water, it does not regulate the pressure.
With the filter, there is just a slight delay in equalization. Too small most certainly to be noticeable.
Just go ahead.
femuse is offline   Reply With Quote
Old 03-10-2003, 07:44 PM   #3
Thanks for the advice...
Thanks Chantal and Mike, I appreciate the advice. These things can be tricky for a rookie like me. Its good to hear from folks with success stories.
Thanks again.
J.Graham
FulFlo water filter tomb Water Heaters, Filters & Pumps 13 10-02-2013 07:57 AM
Water Filter MrTimbo 1974 - 1979 Sovereign 10 08-30-2004 04:18 PM
Everpure Water Filter? jrpappa Water Heaters, Filters & Pumps 4 12-29-2003 12:14 PM
Water heater bypass installation Craig Water Heaters, Filters & Pumps 4 04-05-2003 04:13 PM
Water filter system 53flyingcloud Our Community 2 07-05-2002 04:43 PM
