Old 09-05-2015, 11:30 AM   #1
1995 30' Excella
Chewelah , Washington
Water Filter
Need some information on putting a Water Filter in the supply line. Something that can hook up the supply hose to as well as the supply faucet. I not finding anything on this.
Want to keep all the dirt and stuff out of the trailer plumbing
1995 Excella
Charles
gmshadow is offline   Reply With Quote
Old 09-05-2015, 11:43 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We use the big blue in-line fresh water filters that you can get at Wal-Mart or Camping World. We have used these filter for about ten years now.
We always keep a spare filter on hand as when they clog, it comes without warning.
If you buy the two pack at Wal-Mart, you can save some money
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 09-05-2015, 12:06 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
A Granular Activated Carbon (GAC) filter is a good all-purpose filter for RV use. GAC filters more contaminants that most other filter types. The longer the water remains in the filter, the more effective the filter will be, so get the largest-capacity GAC filter you can find.
The pore size of the filter also helps determine the effectiveness. A 5-micron filter is better than a 10-micron filter.
Connect the filter at the service pedestal end of the hose and it will filter the water before it ever enters the hose, let alone the trailer. Considering how low to the ground some campground spigots are, a short (six inch) section of hose between the spigot and the filter can help.
The first time you use a new filter, run a few gallons of water through it before hooking up, because carbon dust will come out of it, and you want that carbon dust to go on the ground, not into your plumbing.
Also, if you put a screened washer in the short hose in between the filter and the filter, that will block larger debris from even entering the filter, and can be cleaned easily enough by removing the screen periodically to knock accumulated debris out of it.
I put these screened washers not only in the female hose connection at the spigot, but also at my municipal water inlet on the side of the Airstream.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-05-2015, 05:39 PM   #4
1995 30' Excella
Smile
Thank You, Guess will visit Wally World tomorrow. Have trailer hooked up top a well and can't keep it from pushing a little dirt once in awhile. Not much, but enough top plug up screens in short order
Charles
What is best water softener & water filter? 2Tex4Fun Fresh Water Systems 1 10-30-2011 02:42 PM
1969 Overlander Int'l water question - filter on outside water hook up? edmund015 Water Heaters, Filters & Pumps 3 08-20-2009 10:30 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
Water filter system 53flyingcloud Our Community 2 07-05-2002 04:43 PM
Water Filter Follow-Up ViewRVs General Motorhome Topics 6 05-27-2002 10:37 AM
