The valve most likely is the winter bypass for the hot water heater. When in the bypass mode no water will go into the heater and while you are winterizing any blow off will bypass the heater and purge the lines.
As for that rubber hose a picture would help.
There is a drain hose from the condensate tray in the frig but I doubt that the frig is above the heater.
2004 Excursion 4x4
