Old 07-16-2013, 08:49 PM   #1
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
Variable Speed Demand Water Pumps
I am thinking of swapping out my stock Shurflow water pump for a Flojet VSD – the 3.7 gpm model. Reason I’d like to try the VSD pump is to get a quieter pump (hopefully). There is one instruction that makes me question if the VSD will work. “Note: When using a power supply or converter, a battery must be in the circuit for proper operation.” When I’m connected to shore power I normally have the “battery disconnect” switch to “store” so I don’t over-charge the batteries. With that, haven’t I taken the battery out of the circuit? I guess I could always leave the battery in “use” but it wouldn’t make sense (to me) to sacrifice a battery just for that.
I am struggling with why the VSD pumps require a battery in the circuit, whereas other water pumps do not. Is anyone out there using a VSD water pump? Any thoughts on if the VSD pump will work, or if I should even give it a try?
RAH is offline   Reply With Quote
Old 07-16-2013, 08:54 PM   #2
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Are you sure you don't have a varable speed now? My 2011 came with one from new.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 07-16-2013, 09:13 PM   #3
RAH
Cincinnati , Ohio
I don't think I have a variable speed now - it doesn't say VSD anywhere. What model do you have in your 2011 - Shurflow or Flojet?
Old 07-16-2013, 09:21 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, your trailer may be different than mine, but when mine is plugged into shore power it automatically bypasses the store mode.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-16-2013, 09:42 PM   #5
daveswenson's Avatar
2012 28' International
Issaquah , Washington
The store mode isolates the batteries from the 12 volt system. The converter still powers DC but the batteries do not charge or provide power.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 07-16-2013, 10:52 PM   #6
1974 Argosy 20
Kooskia , Idaho
I believe that AS uses the variable speed Sure Flow pump as standard, at least it was standard on the 2013 FC series and my 2014 has one. I am not overly impressed with it but there are far more 90 degree elbows in the intake and outlet distribution piping that AS builds than are necessary. I think my system has way too much friction in it to work properly. That, however is a guess on my part. So, my thoughts are that the piping system is more of a problem than the pump is.
You ask why would a battery be required with the Flo Jet system according to the instructions... I believe it is because many SOB's have a very poor electrical converter charger capacity and they would not supply enough power to run the variable speed pump properly. However, the AS converter/charger is a 55 amp version and has plenty of capacity even without the battery in the system. So, if you did change the pump out I don't think you need to worry about that specification.
If you really want to protect and save your batteries I would recommend you change out the guts of your AS original converter/charger for a PD 46xx 3 stage converter charger for about $200. Then you never have to worry about any long term overcharge or problems and can leave your USE/Store switch on USE all the time.
Old 07-17-2013, 05:32 AM   #7
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
We have a variable speed pump in our 2012 25'FC, you can hear it pick up speed when you increase the water volume.
Gary
Castaway is offline   Reply With Quote
Old 07-17-2013, 07:54 AM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
RAH, I keep the switch in the store mode on shore power as well for the same reason. Our 2012 FC has a variable speed pump.
I wonder why the batteries would have to be in the circuit for the Flojet VSD pump operation. Perhaps a converter can supply the voltage but not the amperage requirement of that pump.
It seems unusual though to have shore electric without shore water supply available.
doug k
Old 07-17-2013, 09:39 AM   #9
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
My 09 has the variable speed pump from the factory.
It runs fine with the the battery switched in use or store.
It is not a quieter pump, by any means.
The most I have done to quieten things down is to add an accumulator tank.
I did this with the full understanding that the factory does not recommend an accumulator tank with variable speed pumps.
With the tank, the water flow is much more even with no surges and the pump is noticeably quieter.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 07-17-2013, 10:50 AM   #10
jay
1974 27' Overlander
danville , New Hampshire
Voltage from the converter is not "clean" DC. With the battery in the circuit the peaks and valleys are filtered out by the battery. If you run the pump direct from the converter you may damage the pump over time.
Jay.
jaygood31 is offline   Reply With Quote
Old 07-17-2013, 11:30 AM   #11
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I've installed a Flojet Var. 3.7 in my 65 Safari and love it. It provides water flow like our house on full and is very quiet. When running lower flows we can't even hear it run.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 07-17-2013, 11:36 AM   #12
jdalrymple's Avatar
Jay , Oklahoma
Jay.
I agree it is not the most filtered power source, but my isn't bad enough to ruin a pump.
Regards,
JD
Jeff & Cindy
'91 350 LE MH
Old 07-19-2013, 02:11 PM   #13
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
I can't make it all out because its under the oven on my unit. It's a Sureflow Start sense 4900-???
I chose America
Old 07-20-2013, 08:30 PM   #14
RAH
Cincinnati , Ohio
Thanks for the advice everyone. I will be putting the Flojet VSD 3.7 gpm in tomorrow. Somewhere along the line my next projects will include surge protection, maybe later changing the converter/charger as idroba suggested in #6 above.
