Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 05-17-2014, 10:35 PM   #21
Naples , Florida
I did my PT RV-500 on my then new '06' 19CCD. I had to remove about an inch and a half from the top skins, and it fit right in.
It took longer to get up the courage to cut the inner/outer skins than it took to install the entire unit.
It worked flawlessly for 6 years, when I sold the trailer.
lewster
Old 05-17-2014, 11:20 PM   #22
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Using Tankless water heater, possibly ventless type
I installed a 7 GPM residential propane unit. It works well, but it would be a tough install as a retrofit.
The cost was over 100 less than the Girard.
Tankless Water Heater Lothlorian Water Heaters, Filters & Pumps 25 12-30-2007 10:30 AM
Tankless water heater GreatPumpkin Off Topic Forum 10 08-25-2006 03:28 PM
Tankless water heater dmadam Water Heaters, Filters & Pumps 26 01-19-2005 09:59 AM
Tankless water heater FC54 Water Heaters, Filters & Pumps 20 10-27-2004 03:18 PM
Tankless water heater spinolio Water Heaters, Filters & Pumps 3 12-21-2002 09:53 PM
