Old 09-16-2013, 01:44 PM   #1
2014 25' FB Eddie Bauer
Knoxville , Tennessee
Under sink water filter
Just got 2014 Eddie Bauer. They asked if I wanted to install the water filter under the sink. I told them no, because the tech was saying what a hassle it was to install/replace. He said alot of people get the outside in-line water filter. The more I think about it, it really don't want or need to filter all my water. I thought I would post to get some opinions about the under the sink filter. I am leaning toward having them install it, now. Thanks for any input!
Jfed is offline   Reply With Quote
Old 09-16-2013, 01:50 PM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Outside filter won't help if you are drinking water from fresh tank, but we tend to carry a gallon jug of drinking water for coffee, etc.. Really depends on how you imagine using trailer.. If you imagine majority of stays at campgrounds or RV parks with hookups, then outside filter is better process, along with pressure regulator. If you imagine a lot of boondocking and using water from fresh tank, then maybe inside filter makes sense. Another option is "Instant Hot" faucet with filter and heater for use to provide hot water for coffee (cone/French press) or tea bags next to sink...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 09-16-2013, 03:53 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Will help for filling the fresh tank, though…
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-16-2013, 05:37 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We don't use it, outside filter only. But we don't drink water from the tank or campground spigots, don't trust either, we drink bottled water.
doug
Old 09-16-2013, 05:41 PM   #5
PhilipKS's Avatar
1999 34' Excella
NE Central , Kansas
I use mine all the time. Also use an outside filter.
AIR 57698, TAC NM-9. http://www.flickr.com/photos/philipks/
PhilipKS is offline   Reply With Quote
Old 09-16-2013, 08:38 PM   #6
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
Philip,
Same here. We get a new outside filter every season.
The inside water filter is great. We use it all the time - drinking water, making coffee, brushing teeth etc.
We didn't have the under sink water filter in any of our previous coaches.
I would definitely recommend getting the filter.
Tom
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 09-16-2013, 09:17 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
New outie and innie, yearly.... Or if I have plugged into questionable source.
Filters cheaper than the Vet.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-16-2013, 09:24 PM   #8
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, although I don't have an under the sink water filter, I think the real concern is for when it's time to winterize your trailer [something that I never do] and you have to remove the filter and install a bypass tube in it's place. Then later, you have to re-install the filter. I have an in-line water filter, but I have never used it; We bring bottled water.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-16-2013, 09:29 PM   #9
dznf0g's Avatar
Oswego , Illinois
I think they all have a shutoff valve. Just remove the filter housing, drain and no antifreeze goes to the filter when winterizing. At least that's how mine is.
-Rich-
Old 09-17-2013, 08:33 AM   #10
Skater's Avatar
1995 30' Excella
Bowie , Maryland
My undersink filter has a bypass plug that goes in for when you're blowing out lines. It's not meant to hold pressure against liquids, so it's not clear to me what you're supposed to do if you use antifreeze...I guess just use a retired filter.
We replace the filter each spring...it's about $30 from Camping World. But we probably spent at least half that much in bottled water anyway before we started using the filter, and this is far more convenient. Since I usually winterize at least twice a year, we keep the filter in a gallon ziplock bag in the house when the camper is winterized.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 09-17-2013, 10:17 AM   #11
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
We use both inside and outside, replace annually in the Spring. Worth it.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 09-17-2013, 11:27 AM   #12
Bbelk's Avatar
2010 27' FB Classic
We have lived off the on-board water in various campers for years and never had a filter and never had a problem until we spent a month in one spot filling the tank from a well with no chlorine. The symptoms we picked up matched what I used to get in Mexico after a week so we suspected the water and started using a little bleach and have not had another problem.
The new trailer has a filter under the sink the feeds just the one drinking water spigot on the sink.
About that drinking water filter. It is mounted flat on the shelf under the sink taking up a bunch of space. There there a reason they didn't mount it vertically. There seems to be room.
2010 27FB Classic
1989 190 Class B (Sold)
1977 29 Ambassador Land Yacht (Sold)
Bbelk is online now   Reply With Quote
