Old 08-21-2016, 12:23 PM   #1
U-tube design
Hello all,
I am having some issues with my Bowen G610-3B water heater. When ignited, the flame shoots out of the inlet of the u-tube, rather than through the inlet and out the exhaust end. I have tried to push a wire through, to clear any possible obstructions, but the tube is not cylindrical all the way through. I was able to negotiate he wire through once, but there was certainly not enough room to "tie a rag onto it, and pull it through to clear the soot". Has my u-tube been damaged, or is the a part of the design? I hope the pictures will help.
ThanksClick image for larger version
Name:	ImageUploadedByAirstream Forums1471803730.500822.jpg
ID:	269685Click image for larger version
Name:	ImageUploadedByAirstream Forums1471803759.559773.jpg
10sscott is offline   Reply With Quote
Old 08-21-2016, 12:51 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
It is clearly not soot that is the problem. There are most likely baffles in there to direct the flame against the walls of the tube.
I would try compressed air while holding a clean rag over the outlet end. I say this to see if any nesting material blows out.
2004 Excursion 4x4
Old 08-21-2016, 01:04 PM   #3
2007 22' International CCD
And to keep from getting a face full of soot😀😀😀
Old 08-21-2016, 01:15 PM   #4
Thanks! I only got a little dirt out with air, hopefully it will help- once I get the trailer back together.
Old 08-21-2016, 01:50 PM   #5
1973 31' Sovereign
Middletown , California
Try blowing a hair dryer into it and feel if the same amount of air comes out as goes in. I don't think there are any baffles or anything in my 10 gallon unit and it looks round and symmetrical as far as I can see. You may have a nest in there or it may have been fired when empty and melted the tube.
ijustlee is offline   Reply With Quote
Old 08-21-2016, 02:01 PM   #6
Thanks ijustlee, the tube melting would explain the weird shaping inside.
How do I clean my AC drain tube? tyndalelady Furnaces, Heaters, Fireplaces & Air Conditioning 67 05-13-2013 11:55 AM
? carter shade awning roller tube retro-active-couple Awnings 3 06-23-2004 03:56 PM
Fresh water filler tube '63 Safari srgntpepper Fresh Water Systems 5 05-27-2004 07:16 AM
Tube type tires for 77 alum rims Mike B Tires 10 04-09-2003 08:04 PM
