Old 01-08-2006, 10:41 PM   #1
1991 25' Excella
SF Bay Area , California
Question two water pump switches?
Why are there two water pump switches – one in the bathroom and one in the kitchen? thanks
aeriqua is offline   Reply With Quote
Old 01-09-2006, 02:54 AM   #2
1993 29' Excella
Jonesboro , Louisiana
The two switches are there for your convenience. The water pump can be turned on or off at either location. Electrically these switches simply complete the ground path for the pump motor to operate.
James Schmidt
29 ft Excello 1000
97 Expedition/Hensley Hitch/
McKesh mirrors
James Schmidt is offline   Reply With Quote
Old 01-09-2006, 06:45 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Many people, myself included, turn the water pump off at night. With the pump switch in the bathroom (mine does not have this option), it makes the middle of the night trip to the bathroom more convienent. They are wired so that flipping either switch changes the state (on/off) of the water pump.
Richard
Old 01-09-2006, 12:53 PM   #4
cammur's Avatar
Roseville , California
I think the two switches are a good thing, for convenience, as azfly says. Unfortunately my 2005 Safari has only the kitchen switch, with a "blank" in the bath vanity area. Penny wise, pound foolish (insert your currency of choice).
cammur is offline   Reply With Quote
Old 01-09-2006, 02:11 PM   #5
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
More interesting switches
Just because it sounds like you're getting to know your trailer, I thought I'd toss in reference to odd switch in pantry cabinet over stove... That is switch that turns on or off A/C and Microwave, which can't both be active at same time... This is in the manual, but not real obvious, and caused us to do some troubleshooting of dead outlet behyind microwave 'til we figured it out...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 01-09-2006, 05:17 PM   #6
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
In the "late night noise" category, I feel inclined to point out that the Variable Speed Displacement (VSD) pumps like the late-model FloJet I have in my Overlander do not make any discernable noise in the middle of the night due to some form of drip type leak.
The PAR pumps of old used to hold the system plumbling at 30 psi or so & cycle every so oftern to keep it there. A VSD pump responds to demand, and will not wake you up when it accounts for a mild pressure drop due to a drip.
Two or more switches are great when you are boondocking & trying to conserve battery power, but if most of your camping is on shore power, one water pump switch will suit your needs well.
Tom
Old 01-09-2006, 05:24 PM   #7
2002 25' Safari
Dewey , Arizona
Images: 62
The good news for me is I can get 2+ flushes with out the pump (built up water pressure).
Richard
Old 06-03-2016, 02:47 PM   #8
2003 28' Classic
Ladysmith , Wisconsin
For some reason, my bathroom water pump switch only turns on now when the kitchen water pump switch is in the ON position. If the kitchen water pump is turned OFF position, the bathroom water pump switch will not turn on.
JacobMerridy is offline   Reply With Quote
Old 06-03-2016, 04:14 PM   #9
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I believe they are wired similar to switches at the top and bottom of the staircase - in other words, you cannot go with the marked switch positions - they mean nothing and change each time one switch is flipped!
Not quite as convenient as the upstairs / downstairs light switch setup wherein you can see right away if you have switched the light off!
Sometimes, If I don't remember which pump switch I used last time, I will open the tap a little and see if the pump runs or not to know if I have switched it off!
Not sure I explained that well - hope it makes sense to you!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 06-03-2016, 04:44 PM   #10
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
This is strange. Are all late model AS wired with the second bathroom switch. If they are were is it located. I have a 2013 28' and was not aware of a second switch in the bathroom.
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 06-03-2016, 05:08 PM   #11
dougandlori's Avatar
2004 28' Classic
Fresno , California
My 04 classic has two switches but must be wired incorrectly since the bathroom switch only works with the kitchen switch turned on. I have not looked for a solution but the project is in the job jar.
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
dougandlori is offline   Reply With Quote
Old 06-03-2016, 05:20 PM   #12
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
We have 2 switches as well. One in the bathroom and one in the overhead control panel over the couch. Turn either switch into the on position and this will light a light in the control panel to indicate pump is on, likewise to the off position and the light in the panel goes off. Having the light in the panel is nice to let you know the pump is on or off, good feature. I feel that if you are not using the water the switch should be turned off, foreseeing a leak or some other issue to arise. Playing it safe!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 06-03-2016, 05:21 PM   #13
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
On my 04 Classic, the visual position of the switch on the systems panel or in the bathroom does not indicate whether the pump is on or off. Much like a three way switch in my house. If the pump is off, either switch being changed will activate the pump. If the pump is on, either switch being changed will turn it off. If I'm using my fresh water tank when I arrive, I will flip either switch and then turn on the water to verify the pump is active. When departing for home, I flip a switch to another position and then turn on a faucet to verify that the pump has been deactivated.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-03-2016, 06:01 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Typically a rocker switch is mounted in such a way that when the top half of the switch is depressed it is on. If they are mounted horizontal good luck.
The two switches mentioned above are not wired like 3 way switches in your home. Otherwise either switch would operate the pump on or off.
They appear to be wired in series. Meaning the main switch must be "on" to get power to the secondary switch. There is somewhat of an advantage to this setup which is you only have to turn "off" the main switch to disable the pump.
I have 2 switches wired in parallel. Which means I must make sure both are "off" if I want the pump disabled. I wired the second switch in because I would often use the bathroom and have to go to the galley to turn the pump on. Now I just reach up and operate the switch.
Water Pump cycles often Guitars Water Heaters, Filters & Pumps 3 11-19-2002 07:04 PM
Water Pump Joan D'Andrea Water Heaters, Filters & Pumps 3 11-01-2002 06:31 AM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 09:13 PM
Water pump has quit roessler Water Heaters, Filters & Pumps 8 08-14-2002 03:02 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
