Old 08-29-2012, 08:02 PM   #1
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Troubleshooting the 120v side of the water heater
I'm not sure if the water heater in our '01 Excella is working on the 120v side and would appreciate some guidance on troubleshooting it ??? There is a fuse visable when you look inside the access panel and that was my first thing to check so it's OK. Not sure where to go from there. I'm on the road at the time and will take a closer look at it when we get home.
Thanks all. Didn't see any AS's today while on the road through Iowa, Illinois and into Indiana. Where are you all ????
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 08-29-2012, 08:39 PM   #2
1977 Argosy 24
Milltown , Wisconsin
Are you sure it is a 120 volt ac water heater? The reason I ask is most RV water heaters are propane only, unless you converted it or ordered it that way.
ventport is offline   Reply With Quote
Old 08-29-2012, 08:51 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
For informational purposes:
The heater model is a GC6AA-9E
Electronic Models
GCH6A-9E
Electronic Ignition Version Type of heating element
(GC_ A - _ _ = bolt on, GC_ A A-_ _ = screw in) Gallon capacity (6 or 10) H =Engine heat exchange/ Combination gas and 110VAC electric
Propane Gas
His is a gas/electric combination unit but does not have the heat exchange option.
Old 02-28-2013, 09:22 AM   #4
Member Slide Out Society
2004 28' Safari S/O
Zavalla , Texas Airstream Harbor
Hot water heater woes
The electronic thermostat that is on eht side of the water tank appears to be bad that feeds the electricity to the heating element. Anyone suggest a way to test or check it?
Rockwell is offline   Reply With Quote
Old 02-28-2013, 02:14 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you have access to the terminals or where the wires terminate. Check for power. The device is probably 2 wires. One will be the power in, the other will be the power to the heating element.
If this is the case you will need to put one lead of the meter on the neutral. Then check for power in and out with the other lead.
You could also check at the terminals at the heating element.
If you are not comfortable working with 120 volts AC, get help.
Old 02-28-2013, 08:41 PM   #6
2004 28' Safari S/O
Thanks for the tip. Got it figured out earlier had a reset on the device. Working fine. Appreciate the help
